Use C16, add timing
Old Aug 23, 2006 | 12:04 PM
Bandit 1's Avatar
Use C16, add timing
Stock block Im running a 200 shot and pulling 8 degrees of timing with pump gas. This time i have C16 in the tank and am trying to decide how much timing to add back into it. Any thoughts??
Old Aug 23, 2006 | 12:29 PM
Sparkz28ss's Avatar
Re: Use C16, add timing
26 total..... but they are not my pistons
Old Aug 23, 2006 | 12:48 PM
Without knowing the type of engine and heads.... how could anyone even attempt to answer this question? V6, SBC 1, LT1, LSx????????
Old Aug 23, 2006 | 01:27 PM
Bandit 1's Avatar
I used to have all my mods on my signature I don't know why i took them off but the motor is the best engine of course, its a stock LT1 with bolt-ons. Yeah I know a 200 shot is a little risky and Im not expecting to last long. I have an Pcmforless NA tune the timing is advanced for power to 37 degrees peak and even with me retarding 8 degrees it seems like a lot of timing for a 200 shot and I haven't noticed any detonation or I just don't know how to diagnose detonation that's why Im doing what's in my first post.
Old Aug 25, 2006 | 04:59 PM
Bandit 1's Avatar
I think retarding the timing Zero degrees will work. Maybe I can even put more timing into it.
Old Sep 3, 2006 | 02:19 PM
OBE1 95Z28's Avatar
Timing is reduced not only to prevent knock, but also because the flame front will be advanced with the nitrous. Therefore reducing the timing will make more power.
Old Sep 6, 2006 | 04:29 AM
rskrause's Avatar
Moderator
The cars I've seen on the dyno with C16 don't need much timing. Why do you think you should advance your timing when using it? The only way to really find out is put it on a dyno. Thing is, with a stock bottom end and a 200 shot, you are already pusihing the envelope. You could easily hole a piston or break something big time with too much timing and the nitrous on stock pistons. If I were going to try and tune that kind of combo, I'd start by taking some timing away and see if that helps your traps - you may find you need less timing just as likely as more.
Rich
Old Sep 6, 2006 | 10:11 PM
n20ta2's Avatar
also your using leaded fuel with o2 sensors ?do you have lead safe units? It wont take but a few passes to kill em.
Old Sep 6, 2006 | 10:24 PM
Sparkz28ss's Avatar
Denso makes some good ones.... I run 111 leaded with no problem
HectorM52
Jun 23, 2016 08:42 PM
edman
Jan 22, 2015 02:45 PM
Queens94z28
Dec 20, 2014 09:11 PM
cmdeshon
Dec 12, 2014 10:51 PM
