what shot?
what shot?
my TA has about 130k miles on it....and of course i wanna put nitrous on it cuz i heard lt1s run great with it. if i decide to do it what shot should be the most i should run it? or should i just not even try it? thanks
Re: what shot?
With those miles even if it's in really good running condition, I wouldn't go over a 75-100 shot.....preferably a 75 shot......Just make sure you have a good working ignition, replace the opti if it hasn't been already, a step colder plugs can't hurt even on a small shot, good plug wires, a fuel pressure safety switch, window switch, and a good quality wet kit and it "may" be alright for a while......Before you do a nitrous kit, you may want to perform a leak down (and compression) test to make sure the rings are still sealing well, and the compression is fairly even as well......My honest opinion is that if you can't afford to have it possibly break in a bad way, (like that it's your primary car that you need from day to day), I really wouldn't do it.....good luck.........joe
Re: what shot?
You could try doing a leakdown test on the motor, it'll give you a good idea of what condition it's in.
Matt
Matt
Re: what shot?
How much do you rely on this car (daily driver?) and how prepared are you for a rebuild?
I sprayed 150 for a long time with @ 120k miles never a problem. Swapped in a cam and spun 2 rod bearings in no time because of the 6500rpm runs.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
