WOT switch location?
Old Sep 18, 2006 | 01:12 AM
cc89formula's Avatar
anyone have pics of how they did it?
Old Sep 18, 2006 | 10:03 AM
Moshbmx1's Avatar
Re: WOT switch location?
I mounted mine on the firewall under the gas pedal..i dont have pics but i will try to take some if you want to see
Old Sep 18, 2006 | 01:16 PM
2000GTP's Avatar
I ordered the custom billet bracket from www.nitrousoutlet.com The bracket comes with an attached WOT switch and it is bolted right to the throttle body. I don't have any installed pics., just what it looks like out of the box.
Old Sep 18, 2006 | 02:58 PM
WhyHelloOfficer's Avatar
I keep mine in my glove box
If you're trying to make your setup somewhat hidden.. an electronic TPS Switch is definately the way to go. All you have to do is tap into the TPS signal wire going to the PCM.
If you want more of my hidden setup I'll PM you some links to pics.
Old Sep 18, 2006 | 03:04 PM
i dont want to spend money on something like that, i already have the WOT switch, and my systems not going to be hidden anyway, its hard to hide a plate kit...plus my bottle is mounted on the hump between the rear seats
meissen
Jun 1, 2015 07:59 AM
taner
Aug 26, 2002 10:58 PM
taner
Aug 23, 2002 05:25 PM
taner
Aug 21, 2002 09:49 AM
taner
Aug 18, 2002 08:43 PM
