Help with window switch
Old Jun 12, 2006 | 09:55 PM
94v6a4's Avatar
I am wiring up nitrous on my 95 Z28, and I cannot get the window switch to activate for anything. Everything works when I bypass the window switch. It is a MSD 8956. The tach line is tapped into the pcm. It has 8 volts at idle and the voltage drops to around 5 volts as you rev. If a put a piece of wire into the hole where the pills normally go it activates, so I know it is something with the tach signal. Does anyone have any ideas why this wont work? MSD tech support isn't that helpful.
Old Jun 14, 2006 | 02:18 AM
Bandit 1's Avatar
Re: Help with window switch
How about hooking the rpm signal wire to the negative side of the coil. I believe it would be ok with a stock ignition.
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
