Need some advice on dual stage 150/150HP?
I remember seeing where if you run 2 nozzles the jetting was a little dfferent. I currently have 2 shark nozzles plumbed into the MAF (Ram Air setup) and have only used one for upto 200HP and it's at the limit for one nozzle. I am in the process of hooking up the second stage and was thinking of going 62/35 jets on one stage then start at 100HP on the second stage and work my way up to 150HP. The first stage will be on the WOT switch and then a timer on the second stage. If I use the 62/35 jets on both stages will it be more than 300HP total?
Henson071
08-04-2015 09:32 AM
Catmaigne
07-14-2015 05:17 PM
