how to activate the 2nd stage
Old Jun 5, 2006 | 09:23 PM
jasonisdn's Avatar
ok i am going to use 2 kits. 1 is 125 dry 2nd is 175 wet. the dry kit is going to be used the entire run while i want the wet shot to hit in 2nd gear. i am using a window switch for the dry kit with a TPS switch. how can i wire the second kit to know to come on in 2nd gear . i know i can add another window switch for the rpm area i want it to hit in but the 2nd gear issue has me wondering how to approch it. i havent messed with to many kits in the past so be easy on my @ss . thanks guys
Old Jun 5, 2006 | 10:44 PM
jasonisdn's Avatar
Re: how to activate the 2nd stage
hey has anyone tried this or is this just retarted. what voltage does our speed sensor run at? does it increase like the TPS ? would it be possiable to hook up a TPS switch into the speed sensor ( the adjustable one from zex i guess) to turn the system on when a ceratin speed was reached . with that speed i am guessing that the speed sensor has a certain voltage it will be putting out as a signal to the computer. does that make sense to anyone? hit the desired speed in 2nd gear (cant reach it in first by accident) system arms and starts spraying. now here is the issue i found in that idea , when in the hell willthe system stop spraying ? it would ,i take it, keep spraying in between shifts (i am a manual gear box guy) . could this issue be sloved with a micro switch to send the signal to the TPS switch to cut it off between shifts and at the end of the run. arm the micro switch with a toggle switch i guess. ok either fix this idea or shoot it all to hell. i really dont like the idea of a timing box to control the second stage.
Last edited by jasonisdn; Jun 5, 2006 at 10:46 PM. Reason: i cant spellfor crap and i never proof read
Old Jun 6, 2006 | 10:27 AM
InsuranceGuy's Avatar
You could activate the second stage by using a timer or
a window switch with a 1st gear lockout.
Emil:93Z,383,Vortech, NOS,water/methanol
Old Jun 6, 2006 | 10:51 AM
jasonisdn's Avatar
tell me more about this 1st gear lockout. sounds like a great method to do what i want to do
Old Jun 6, 2006 | 11:45 AM
Daniel6718's Avatar
basic..most wondow switches have it as an option...thats what i would do, spray the big stage first though...150...then 2nd gear comes on with a 100 shot...but you can do it with any amounts...mayb on the second stage have it come on after 3500 to protect the motor. how built is this motor if your spraying 300???
Old Jun 6, 2006 | 12:09 PM
jasonisdn's Avatar
pro gram splayed flat bottom main caps, dragon slayer crank, either bme custom or je custom nitrous pistons , hell fire rings, m55a melling pump i guess thats the key items you are worried about. my current window switc didnt have that option , guess ill have to look for it.
ps AI topend
Old Jun 6, 2006 | 01:10 PM
Here is one from bmnracetech. Check out their FAQ for more details.
http://www.bmnracetech.com/products.html
Emil
Old Jun 6, 2006 | 02:57 PM
jasonisdn's Avatar
Emil
thanks for the link , i like the looks of that mother fudger.
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 10:09 AM
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
