NX safety nut tap size...
I just got the NX shark nozzle with the safety nut setup, I didnt get instructions with it and am not sure what size tap and drill bit to get. Does anyone have install instructions?
Re: NX safety nut tap size...
i guess I don't know where I'm supposed to install this? Isnt there a sensor that needs to be in that rubber grommet? I have a trickflow intake elbow if that matters. can anyone give me a breif install guide to this safety nut for the shark nozzle?
yes that is correct, i guess i thought i threaded the thread part into the elbow then thread the nut on, but i guess it makes sense now that you just drill a hole and tighten it down. Do you know what size the hole needs to be drilled?
http://www.harrisspeedworks.com/gall...album=27&pos=4
Thats where i mounted the nozzle in the trickflow elbow....
Its a 9/16 inch hole, its a pretty big drill bit which I had to run to the hardware store to purchase. You can go to Nitrous Express' website and get an installation manual, http://www.nitrousexpress.com/Instructions/stage1.pdf
surreybrad
09-29-2015 09:00 PM
tdigger9899
09-07-2015 10:56 AM
