Installing p600b need injector/spark plug advice...
I need to know if I can get my car tuned using stock injectors with a my 255lph pump? If its really not feasable to tune with those injectors then how about some 30lbs?
I'm also running "new" stock plugs at stock gap and need to know if I should go a range colder. If so what plugs? Am I correct that regardless of plug choice I need to gap them at .35 ?
Thanks guys
Adam
Thanks guys
Adam
Re: Installing p600b need injector/spark plug advice...
Im guessing without the FMU your probably going to need 42#'s With the FMU I think you can stay stock, but the FMU's suck, either rich or KA-Boom.
As far as plugs I think it should say right in the instructions for the blower NOT to use Platnum plugs. Every blower I have installed it said it in bold print. Ditch the stock plugs and go to a NGK TR6 or a autolite plain Jane plug and one heat range cooler, and knock the gap back to .035 to start, If you have ignition break up back them up to .030. (I think the autolite # is 104????? the stock heat range is 106?)
Thanks for the info...are you saying that going to 30lb injectors won't really do me anygood with the fmu installed? I need to go all the way to 42lb? Any other suggestions are welcomed.
Adam
The stock 24# injectors aren't going to supply enough fuel for a boosted engine without an FMU. 30's will provide more fuel, but you may still run out at high RPM even at low boost. A 36 or 42 pound injector should be able to supply enough fuel to keep the engine happy. The reason 42s are suggested is because it's better to go to big than to small when it comes to stock pistons and forced induction.
Originally Posted by hellostop
Irridiam plugs by Nipon will not foul, but are $13 each. How much do you like changing them?
My tuner said they're as foul proof as it gets, any better ideas appreciated.
Thinking of adding a Delteq. Tuner has retarded PCM timing so LTCC seems overkill. Thoughts?
I'm trying to get D1SC twin i/c's dialed in.
Magenta_Hearts
Mar 25, 2015 10:24 AM
jasonduaine
Mar 7, 2015 09:44 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
