What would be a good blower for this setup???
Old Oct 14, 2004 | 10:21 AM
texasTA's Avatar
I am a complete newbie when it comes to the world of forced induction. I have done a little research by looking over the 4 pages on here for info.
I am getting a set of LT4 heads/intake manifold fully ported right now as we speak. As soon as the top pieces are back, the short block will begin its buildup. I have decided to go with a 383.
So my question is, with my soon to be setup, what would be a good blower to go with on my setup? This will be a cruiser/strip car. I go on the Hot Rod Power Tours and to a lot of local car shows. I also enjoy driving the car around on nice days. But I do have a beater to serve as my main means of transportation.
Setup:
fully forged 383
stage 3 LT4 heads
fully ported LT4 intake manifold
58mm Monoblade
custom Cam Motion cam (i will wait to get it ground until I get the head flow numbers and motor size/compression, etc..)
1.6 rockers (7/16 NSA Comp cams Pro mags)
comp R lifters
Hooker Longtubes
True Duals
Fully built 4l60-E tranny
3600 Super yank stall convertor
aluminum driveshaft 1LE
BMR k-member
BMR trak pak torque arm
BMR panhard rod
BMR boxed LCAs
BMR subframe connectors
3.73 gears
Racetronix fuel pump
I am not sure which size injectors to use, as this will be dictated by the setup.
So with those mods, what would be a good blower? And what compression should I shoot for to use a blower and make some good boost13-14psi
Old Oct 15, 2004 | 12:19 PM
texasTA's Avatar
Re: What would be a good blower for this setup???
ne1
Old Oct 15, 2004 | 02:59 PM
KS91Z28's Avatar
9:1 with an F1 IMHO
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
1LEThumper
Jul 14, 2003 12:45 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
