Driveability of 383 Blower Motor without a Blower?
Old Sep 22, 2004 | 03:54 PM
Mikey97Z's Avatar
Question Driveability of 383 Blower Motor without a Blower?
I was wondering ... if I built a low-compression 383, but didn't have the blower yet, how slow would it be? Assuming 8.5:1 compression and 224/236/114 cam. I think it would have some good low end torque with that cam. But how much will the 8.5:1 compression hurt (compared to 10.5:1)? Could it still come close to 400 RWHP? thanks.
Old Sep 22, 2004 | 04:34 PM
Josh-'04 GTO's Avatar
Re: Driveability of 383 Blower Motor without a Blower?
General rule of thumb is 4% per point of compression. So expect a 30-35 horsepower dropoff by lowering the compression 2 full points. The car should have decent power and good driveability, but blower cams are not effective at filling cylinder bores naturally aspirated since they don't have much overlap. IOW, it won't be a powerhouse without the blower.
Old Sep 22, 2004 | 05:24 PM
engineermike's Avatar
I once built a blower motor and ran it NA for a while. It was a 3rd gen with an 8.5/1 360 cid SBC, AFR 210's, GM 847 cam (234/242), Victor Jr, and Holley 750. All of these parts are supposed to kill low-end, but the car ran a best of 11.96 at 114.5 NA - on 87 octane.
Mike
Old Sep 22, 2004 | 07:49 PM
Mike
Those are good numbers, but the GM847 isn't exactly a "blower cam", so it's gonna be a little tough to compare your motor to Mikey97Z's setup. That 847 has more overlap than a normal "blower" cam, which was great when you ran it N/A. I'm sure your set of AFR 210s didn't hurt either.
Old Sep 22, 2004 | 08:51 PM
rskrause's Avatar
Moderator
It will be far from "slow". The loss in hp will be in the 5-7% range.
Rich
Old Sep 22, 2004 | 09:10 PM
I don't think the 847 is that far off from a blower cam. A 112 LSA is pretty wide. In fact, mose blower cam experts agree that 112-114 is the range you want to be in. Compare my current 224/236-114 to the 847 and you see that the 847 has 14 degrees of overlap versus 2 degrees in my current cam (@.050). A good NA cam will have more like 50 - 60 deg of overlap at .050". So, I really don't think the extra 12 deg of overlap helped me that much NA.
If anything, the longer duration of the 847 hurt me even more because of the low compression. DCR was especially low with 8.5/1 static combined with 296 advertised duration.
Mike
Old Sep 22, 2004 | 09:23 PM
Mike
I wouldn't run a 112 LSA on a blower specific motor IMO. Agreed, 12 degrees isn't a huge difference, but it is there.
The longer duration cam would be a help to your old combo, IMO. AFR 210s are "large" runners on a 360cid, and coupled with the Victor Jr. manifold, would lend that engine to do well in the higher end of the powerband; playing right into that cams strength.
Old Sep 22, 2004 | 09:45 PM
I think that the converse is true. The "large" runners and Victor Jr. are suited for high end, but not so good on low-end. With the low compression, a short duration cam would perform better because it would help get the DCR up and partially offset the effects of the Victor Jr. and 210 cc ports.
Big ports + Victor Jr. + big cam + low compression = soggy bottom end
On the dyno, with the converter locked, it made 337 ft-lb peak at 5000 rpm. I can thank the Vigilante 3200 for masking the lack of low-end and allowing me to run 1.6 60' times.
Mike
Old Sep 23, 2004 | 10:46 AM
bumpin_records's Avatar
put nos on it till you get a blower
Old Sep 23, 2004 | 11:36 AM
Roadie's Avatar
heh. ricer say nawwwwwz?
now back to your regularly scheduled thread...
Old Sep 23, 2004 | 04:21 PM
Mike
I think we're saying the same thing. I'm saying:
GM847 + AFR210 + Victor Jr= great top end, thus explaining your great track times with a motor that wasn't expected to be great when run N/A. I definitely agree about the soggy bottom end, but as you mentioned, a Vig 3200 does a great job of band-aiding that.
Old Sep 23, 2004 | 10:59 PM
BlownF1's Avatar
Good timing...I've recently completed my install of a similiar setup to what you describe and I was worried about the same thing initially. I've got an 8.3-8.5:1 383 blower motor with that 224/236-114 cam. With the blower belt on it's "snappy" and super-responsive...with the blower belt off, it's still got tons of torque and power, just isn't as snappy feeling. As soon as you step on it though, it wants to go...I wouldn't worry about it at all, it's made out to sound like far more of an issue than it really is...go for it! Rich told me that's how it'd be and since I trust his opinion, I went for it and have no regrets! P.S. Thanks Rich!!!
Old Sep 23, 2004 | 11:54 PM
rskrause's Avatar
Moderator
You are quite welcome! Glad it's working out well.
Rich
Old Sep 24, 2004 | 12:27 PM
383WS6's Avatar
just out of curiousity, would the same be true w/ a turbo cam in a built 383? it looks like it's going to be a while before i can complete this project and i've already got the cam that Jordon Musser ordered for me in it. i've driven it for a while and haven't really noticed a huge hp loss, but was wondering if it is safe to drive it this way.
Old Sep 25, 2004 | 02:04 PM
Mikey97Z's Avatar
Cool!! Thanks Brian (and Rich), I am so psyched to start my 383 now!!
D1SC383LT4
Jan 1, 2016 01:56 PM
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
MadMav
Dec 14, 2014 06:19 AM
