Realistic expectations and suggestions?
Old Oct 2, 2004 | 09:25 PM
30thCamaroZ's Avatar
Well I am purchasing a P600b from a board member for my 410ci LT1. I know like I've stated in a previous thread it's not the ideal blower but it's boost for now and later I may upgrade the head unit to a D1 or an F1 if that plate will work. Anyways, I'm leaning towards using an AFR 215 RR head and not sure whether to go solid roller or hydraulic roller. I am undecided on compression as I'm going to have to change the pistons now and need to decide what compression I should run as I want to plan for upgrading to a bigger head unit down the road. I was wondering if I can see 10 pounds out of that P600b and with those AFR 215rr heads and either a solid or hydraulic cam what I could expect? I know there's a lot that plays into it. but lets say 8.5:1 compression for now and it will be intercooled incase that matters.
Old Oct 2, 2004 | 11:46 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: Realistic expectations and suggestions?
I would reccomend against a p600 for a nice setup like you have!
I would go with at LEAST a Vortech Strim, but better yet a T or even YSi trim.
Old Oct 3, 2004 | 01:09 PM
KS91Z28's Avatar
Actually, an F1 or an F1R would be better than the P600 for your setup.
Old Oct 3, 2004 | 01:34 PM
Yeah I realize a bigger blower would be better. I just picked up the P600b for a good price and I will change out the head unit after a while. Shoot I may just build a 355 and put the P600b on there for now and beat that up for a while until I can save up for an F1 head unit.
2QUIK6
Sep 17, 2016 02:31 PM
WPHIG2
Aug 27, 2015 06:37 AM
nd4spd200
Aug 21, 2015 09:30 AM
4586
Jul 31, 2015 06:03 PM
