So close yet so far away......
Started off with a 1.471 sixty ft ran 107.70 in the 1/8th (a new best fow now) and ran 10.094 @ 134.63
Let it cool and went back up and cut a 1.515 sixty ft, ran 106.99 in the 1/8th and short shifted third and went 10.218 @ 134.06......how do you short shift an automatic you ask????? well I've had some issues with my T-com going from first to third so I programmed the t-com to shift 1/2 at 6400 and shifted the 2/3 manually.
Tried a different launch technique and quickly learned that it didn't work.
1.624 sixty ft, 106.93 in the 1/8th and 10.373 @ 134.52
Now back to what I know works.....
1.446 sixty ft, 108.15 in the 1/8th and........
10.051 @ 135.05
Let it cool and went back up for more......
1.470 sixty ft, 108.66 in the 1/8th and........
10.027 @ 135.71 Bitch huh?
Marc
10.051 @ 135.05
Marc
Re: So close yet so far away......
Originally Posted by Lisa33
Nice times, but yes they could be nicer
Are stil running the 4l60e?
What was youre 1/8 times?
On my last two passes it ran 6.425 (on both passes) and as I mentioned before the speed was 108ish.
MN, I hear ya.
I'll update the sig when the spirit moves me
Temp was in the high 60's.
These times were run with FLP dual cats on the car (and not hogged out either), also running stock salad shooters up front.
Marc
Im impressed of youre times
and about the 4l60e
what have you done to it
im installing a 4l80e this winter and im not near youre times
Also gonna install a pair trickflows and a new cam...
I broke 2 pistons last race so its time for a upgrade
Here is a clip from the last race http://forum.camaro.nu/filmer/z28_040912.mov
In the last race it hit the (pcm) rev limiter hard no fuel and 2 pistons gone
and about the 4l60e
and about the 4l60e
and about the 4l60e
...I had the tranny rebuilt by SRA Transmission out of Portsmouth Rhode Island.
Here is the 10.02 video and timelips of my best two runs.
http://www.tta89.net/marc/10zerorun.MPG
http://www.tta89.net/marc/10-02run.jpg
Marc
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
tdigger9899
Sep 7, 2015 10:56 AM
