put me over the 500rw mark
Old Oct 16, 2004 | 01:23 PM
Schurters LT1's Avatar
i am doing somthing to my car this winter and i want power like 500rw pump gas...
i am pulling the eng out and doing what i need to do if i go SC or N/A
What SC do i need and how much boost pump gas (gas94)
what fuel pump
what inj
what parts in the bottom end
heads
cam
this is all new to me so i need all the help here with SC
thx
Old Oct 16, 2004 | 03:58 PM
BruceVette's Avatar
Re: put me over the 500rw mark
Do a budget 355ci with 12psi of boost can easily put you in the 500rwhp range.
Reuse stock crank and rods, use ARP rod bolts and a set of forged piston. TRW have the cheapest piston you can buy and very decent piston for your hp level. Walbro 255lph intank pump will do the job just fine and a 42s or a 50s injectors. Ported your stock LT1 heads.
BRuce
Old Oct 18, 2004 | 04:21 PM
Sorry , so then how much boost on pump gas, and what size of SC oe how much HP/TQ can be made with pump gas..
Old Oct 18, 2004 | 10:41 PM
CJ's Avatar
CJ
You probably want to limit yourself to around 12#s with a budget rebuild on pump gas. Any procharger or vortech blower should work. The numbers in my sig are on a budget rebuild similar to what Bruce described.
Victor Lamb
Aug 26, 2017 02:52 PM
meissen
Jun 1, 2015 07:59 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
ChrisFrez
Dec 7, 2014 11:32 AM
Z284ever
57
Aug 4, 2002 03:48 PM
