55lb injectors too much for my application?
Old Sep 20, 2004 | 04:12 PM
slimdawson's Avatar
I have been looking at injectors and have seen some 55lb. I am currently stock long block with 8 lbs of boost. I will eventually go to heads, cam and possibly stroker. Are they too big for right now?
Thanks.
Old Sep 20, 2004 | 07:10 PM
slimdawson's Avatar
Re: 55lb injectors too much for my application?
Also, I see a lot for sale on Mustang boards. Which ones for Mustangs will also fit LT1s?
Old Sep 20, 2004 | 07:28 PM
engineermike's Avatar
You can't put "too much" injector in a car. You could run up to 84 lb/hr and it would work fine as long as it's tuned. FMS/SVO injectors are the same as LT1's. Just be careful with the high Z / low Z issue. Most injectors over 42 lb/hr are low impedence and will burn up your computer.
Mike
Old Sep 20, 2004 | 10:43 PM
carnutz's Avatar
I am pretty sure when you get huge injectors getting the pulsewidth down low enough for it to idle may be a problem. That is why you dont want injectors bigger than what you need ???
Someone prove me wrong. Please
Old Sep 21, 2004 | 01:30 AM
slimdawson's Avatar
I just bought some new Lucas 42.5 lbs injectors. Thanks though.
Old Sep 21, 2004 | 06:16 AM
With anything below about 95 lb/hr, the computer will cut pulsewidth and it will idle fine.
Mike
Old Sep 21, 2004 | 08:38 AM
carnutz's Avatar
Talking Re: 55lb injectors too much for my application?
Cool!
Anyone got big injectors they wana sell cheap? I have 42#'s but they will be too small shortly........
Old Sep 21, 2004 | 06:34 PM
Live for TAs's Avatar
When I shopped for my 55# high-Z units, Racetronix (supporting vendor) had the best deal, but was out of stock of the Siemens 3172 units. I then tried to buy a set from a F**d aftermarket vendor in Georgia (nice people, very slow response) and ended up buying them from the "Injector Dude". My idle is somewhat choppy (especially w/ AC on), but I have not had anything other than a PCM4Less tune at this point, and the engine is not even broken in.
Amen. Reminds me of the commercial where the couple is looking at TVs, and the guy says "We might as well go big now, or we'll regret it later" and then they are looking at rings & the girl says the same thing .
13qtr
Oct 28, 2016 08:11 PM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
4586
Aug 22, 2015 01:09 AM
Anon
Jul 23, 2015 12:18 PM
