Vortech Oil feed
Old Sep 30, 2004 | 03:57 PM
Alvin@pcmforless.com's Avatar
Vortech Oil feed
Whats the deal with these things? It says not to use Tephlon tape on the threads but how the hell are you supposed to keep it from leaking?
Its in such a wierd place you can't get a wrench on the assembly to tighten all the way.
Is tephlon paste ok to use?
Old Sep 30, 2004 | 08:38 PM
97WS6SCharged's Avatar
Re: Vortech Oil feed
You're just supposed to lightly coat the threads in oil according to the instructions.
Old Oct 1, 2004 | 02:03 AM
carnutz's Avatar
They just dont want ANYTHING to plug the orfice. use some pase on the THREADS, making sure it does NOT get into the end of the fitting or the line and you will be ok.
Old Oct 1, 2004 | 10:15 PM
I took it apart and put tephlon on it. I was careful not to get any extra anywhere.
Stuiped instructions, what the hell do they know? with as small as oil is how can you not put tephlon on the threads.
Old Oct 1, 2004 | 10:32 PM
I didn't use any. The fittings are designed to seal up as you tighten them.
Old Oct 1, 2004 | 10:37 PM
jeez.. i had a 180# fella standing on a drill press vise as i was loosening some of the fittings and I could actually pick him up.
Old Oct 2, 2004 | 02:18 AM
engineermike's Avatar
We don't allow any Teflon tape in lube oil piping in our major compressor and turbine trains and the plant. Bits of Teflon find their way into bearings and orifices and crash the equipment. Most pipe and tubing fittings are designed to seal with no sealer.
Mike
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
Mar 26, 2015 01:50 AM
onefastgta
Mar 19, 2015 10:10 AM
