Turbine housing A/R ratio question
Is the reason the larger A/R ratio turbine housings make more top end the fact that they are less restrictive to exhaust flow? I figure if it had the same compressor side that was running the same boost this seems like the only reason it would give more top end...
Re: Turbine housing A/R ratio question
