To o-ring or not?
Old Sep 21, 2004 | 09:54 PM
blown69nova's Avatar
To o-ring or not?
I'm building a 383 L98 engine for my 69 Nova. What I need to know is what you guys are using for head gaskets? The Cometic MLS gaskets sound good but will they hold up to say 12-15 psi, or should I o-ring it and use copper gaskets? Do copper gaskets tend to leak water? Thanks for any help you can give.
Steve
Old Sep 22, 2004 | 12:08 PM
sleeperz28's Avatar
Re: To o-ring or not?
try a search
Old Sep 22, 2004 | 06:49 PM
Unhappy Re: To o-ring or not?
Sorry guys I tried searching for "head gaskets" and I can't find anything! Maybe I'm just new. If anyone has an opinion on head gasket for blown motors I need your help. I'm at a disadvantage here because guys with older cars don't do this kind of stuff!
Thanks, Steve
Old Sep 22, 2004 | 07:04 PM
Sean94Z's Avatar
Hope this helps .. BTW, I went to the upper right hand corner to SEARCH and typed O-Ring .
http://web.camaross.com/forums/showt...ghlight=o-ring
FYI. I have an LT1, I run over 15#'s of boost on ARP Studs and Felpro Gaskets, and I haven't blown the gasket yet.
--Sean
Old Sep 22, 2004 | 08:27 PM
Jeff 96 SS's Avatar
Go with Cometic Gaskets don't bother with O-rings and copper head gaskets they are a pain trust me I know! I have never been able to get mine to seal they always seem to leak some coolant under boost. If I could do it over I would use the Cometic gaskets.
Jeff
96 SS BLOWN
96 TA 396 D1+N2O
Old Sep 22, 2004 | 10:27 PM
Thumbs up Re: To o-ring or not?
Thanks alot guys, very helpful info! By the way cometic or fel pro loc wire ( w/ studs) sounds like the way to go.
Old Sep 23, 2004 | 05:04 AM
rskrause's Avatar
Moderator
I second Jeff's comments about copper gaskets. They are not for street cars, IMHO. They always seep if not outright leak.
Rich
grabbem88
Mar 25, 2015 12:09 PM
Mizz96Z28
Apr 24, 2004 01:41 PM
prisoner881
Mar 31, 2004 02:21 PM
md1
Mar 30, 2004 09:53 AM
mineralwater
Apr 7, 2003 06:22 PM
