oil leak
Old Sep 21, 2004 | 05:13 PM
greenz2895's Avatar
Unhappy oil leak
i put a 12lb procharger kit on my car and took it for a ride and it started to smoke from under the hood.so i look to see what it was and my firewall had oil on it up by the cowl right behind the motor.and there was also oil right below my the throttle body
Old Sep 21, 2004 | 05:19 PM
agrsiv95's Avatar
Re: oil leak
Is the motor stock? How many miles? Did you move/remove and install a breather in the pass side valve cover? It may be from the hose that runs from the back of the pass side valve cover to the throttle body that blew off under boost.
J
Old Sep 21, 2004 | 07:17 PM
SMOKNZ's Avatar
Re: oil leak
Ringlands
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
