what type pf plugs for SC?
Old Sep 24, 2004 | 10:14 AM
flusz28's Avatar
i have standard ac delco and want to upgrade to something better. i have accel 8mm wires.
Old Sep 24, 2004 | 10:31 AM
agrsiv95's Avatar
Re: what type pf plugs for SC?
For stock heads, NGK TR6 or Autolite 104's seem to be popular.
J
Old Sep 24, 2004 | 10:35 AM
TenaciousDB's Avatar
There are plenty of great threads on what plugs are good to run. Do a search in this forum for "plug" or "plugs" and you'll find lots to sift through. I'm assuming you have a supercharger or turbo if you're asking in this forum. If not, this advice doesn't pertain.
In a forced induction environment, generally you want to go a couple heat ranges colder, gap them smaller, and stick with a copper plug. (No platinum or that Bosch +4 stuff.) I've used Autolite 103's in the past and I'm running ACDelco R42LTS plugs now.
Dave
Old Sep 24, 2004 | 01:44 PM
1st and goal's Avatar
I run Autolite 103's as well (now and back in the day when I was using a P600B on the stock motor).
When I first put the blower on the car I ran NGK's but found the gap opening up on them.
Autolites are also a C/H smaller in overall length so they give you a little more header clearance as well.
Marc
blkWidow
Sep 6, 2015 05:17 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
blac94Z
Feb 23, 2015 04:29 PM
