Felpro 9966 headgasket?
Old Oct 14, 2004 | 04:29 PM
NiteRyda's Avatar
This is a stock replacement headgasket for the LT-1. I am going to place a 383 in my car next week and has wondering is this a good gasket to use to help lower compression on my setup. I will be using TFS 23* heads and -20cc dished pistons. Or should i go with the 1074 head gaskets which i have seen a lot of people with forced induction use. Looking at getting 10 psi with a P-1Sc with 2 core intercooler. Do you guys know of what size pulley do i need?
Thank's
Old Oct 14, 2004 | 04:43 PM
Acct 23749's Avatar
Re: Felpro 9966 headgasket?
Thank's
dont use the stock replacement one, use at least 1074
just pully it up to near max blower rpm....p1-sc is 62,000rpm
ratio of crank to blower pully size x 4.10 x max rpm your gunna use with your motor
Old Oct 14, 2004 | 07:01 PM
NiteRyda's Avatar
What Psi can i get form the P-1sc
What kinda max psi range with the a P-1sc on a 383 with the two core or stepping up to a 3 core intercooler.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
blaze309
Sep 8, 2015 05:27 PM
dylan1303
May 22, 2015 12:24 PM
