Get away with 38lb injectors on 8# ATI no FMU?
Old Sep 11, 2004 | 11:06 PM
Yby4n95Z's Avatar
I know most go 42lb injectors to eliminate the FMU on the ATI procharger. Think 38Lb would do the trick? Came across a good deal on a set.
Adam
Old Sep 12, 2004 | 12:05 AM
1BadAzzGT's Avatar
Re: Get away with 38lb injectors on 8# ATI no FMU?
Adam
Adam,
I wouldn't trust it but it's up to you.
Old Sep 13, 2004 | 06:41 AM
Bone Maro's Avatar
Originally Posted by 1BadAzzGT
Adam,
These were my injectors and they behaved just fine at 476rwhp and making 6psi. The only reason I sold them to Adam is because they won't support 500+rwhp and I upgraded to 50# injectors.
I too had an FMU and had fueling issues. These 38s were the remedy and did their job well
Old Sep 13, 2004 | 10:42 PM
blk95zm6's Avatar
I run 30's....100 percent duty cycle at WOT...Briefly...
455 RWHP, 447RWTQ....58 psi FP at idle, no fmu....
I'm programmed that way, "safe", is a relative term...No knock, showing 900's on my o2's....
Hoping to get my larger (proper sized) injector's soon, but this does work for now...
Old Sep 14, 2004 | 11:52 AM
DarkblueTA's Avatar
Adam
I'm doing the same thing. 38# injectors, 7# of boost, with no problems.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
