Ideal budget bottom end.
Old Sep 21, 2004 | 09:27 AM
Sneakin Deacon's Avatar
i understand, you get what you pay for, but what would be an ideal budget bottom end.
my goals are 420-450rwhp RELIABLY..with long tubes(and cutouts), stock heads, mild cam, V1 S-trim @ 8-12psi and tuning.
now with that in mind, would i be ok to run the stock crank or maybe a scat cast crank? what about rods? should i go to a 355 setup? or should i go big now and go 383? suggestions on pistons/rods/crank aswell? id like to keep some low end grunt, so i think 9:1 is about as low as id like for compression.
or like i said, to keep it a budget setup, keep the stock bore and save a few hundred on machine work?
all suggestions are very welcome, and TIA.
Old Sep 21, 2004 | 10:09 AM
Ucantcme57's Avatar
Re: Ideal budget bottom end.
Got to know what you want to build and then look for the parts..
I waited for a year to get all my parts.. Some agree with where I got them others dont..
Eagle 6" 4340 H-Beam Rods = 275.00
Thunder racing 3.875" 4340 350 Main Crank = 375.00
Wiseco 4.180 20CC Dished forged Pistons = 525.00
Dart Little M Block = 1100.00
Motown 220 Heads = 1200.00
Total = 3200.00
For a 427.. I think it's a good buy..
Prices include Shipping.. All Bought off Ebay.. Some don't recommend.. I just checked ratings, called and spoke with sellers...
Old Sep 21, 2004 | 10:50 AM
rskrause's Avatar
Moderator
Stock crank and rods with a good set of pistons should do fine for power in that range.
Rich
Old Sep 21, 2004 | 05:51 PM
97SS ragtop #077's Avatar
i was at 537 rwhp and stock crank and rods, arp bolts,small cam too. i wonder why i "upgraded"? btw, 11.00@124 with a rag top...
Old Sep 22, 2004 | 09:33 AM
carnutz's Avatar
I have one that makes ~500 at the wheels, stock crank, Eagle H beams, SRP pistons, 9 to 1, ballanced up, stock heads with little pocket work, small cam, ATI provided 8# in front of an auto that went 10.87 @128. The rods are a piece of mind thing, it probably would be fine with a set of well preped stockers.
Old Sep 23, 2004 | 02:00 PM
alright thanks guys...im thinking my 420 goal will be very easy to achieve now...i put down almost 380 yesterday...6spd, 3.23's, 8psi, stock cam, stock heads, stock exhaust..solid 12.2-12.8AF..
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
Z Power
Sep 19, 2015 11:19 PM
FryedClutch
Sep 1, 2015 08:24 AM
whitehooptie
Aug 17, 2015 08:35 AM
