STS Turbo Results - 101 hp gain
We finally got time to install the STS turbo kit on my daily driven 2001 Z28 today. The final result w/ 5 lbs of boost was a gain of 101 rwhp.
I have the dyno graph and an installed pic on our web page here:
http://www.thunderracing.com/project...n=read&pgid=92
My car is an automatic w/ stock torque converter and bolt-on's (Thunder Racing long tube headers w/ custom y-pipe, ASP pulley.) The before runs were done w/ the Hooker cat-back on the car as well. The best I've ever run in the car is 12.25 about a month ago.
Now, if it would just quit pouring down rain so I can get to really drive the car and get it back to the track.
Angie
Angie
Re: STS Turbo Results - 101 hp gain
Angie,
Good luck, hopefully you'll do better than the dumbass who had one of the 4.5 lb kits on an LS-1 T/A at a track rental I went to yesterday.
It was running only low 13's at 111 mph and has dyno'd 411 RWHP
Obviously it was mostly a poor driver (w/ M6) couldn't launch and power shifting had not been mastered.
Looks like you got a clue so you should do fine, look forward to seeing some track times from ya
After you do some test runs, I'd recommend a Vigilante t/c as it would really come screaming out of the hole with one of those.
On a positive note, it did look like a nice kit.
Good luck.
Marc
Good luck.
Marc
Angie, David told me about this last week. I thought about posting it, but didn't know if you guys wanted it spread around.
I'm curious to see how this turbo keeps up with other mod's. Plan on a heads/cam set-up?
Mike
Mike
Originally Posted by 1st and goal
Angie,
Good luck.
Marc
Good luck.
Marc
Mike
Mike
Angie
Angie,
Marc
Marc
Marc, I've run a Vigilante in both my 95 Z28 and my 99 Z28 at different times. I'd say all together, I've been through 6-7 converters between those two cars and the Vigilantes are my favorite for the street/strip. I will most likely go with another one in this car, but I may wait until the 410 is finished before making a final decision on a converter.
Angie
I was skeptical about the STS turbo setup, but after riding in Angie's car today, I must say that I'm impressed. Lag was no worse than any other turbo vehicle I've ridden in and the seat-of-the-pants agrees with the dyno numbers.
Mike
Mike
Originally Posted by robvas
It'd be nice to see some metal heat/dirt sheilds around the intake filter and the turbo housing. Is there a better location for the air intake other than where the tailpipe should be?
I'd hate to have someone remove a banjo fitting while my car is parked somewhere...
We have had the STS system on our LT1 for a year and no problems with the filter. I have thought of a shield also, but havent found a need yet. Probably give it a try when the motor is back in.
Any skeptic has changed their mind about the system after i have given then a ride
cmsmith
Sep 14, 2015 09:09 PM
Is this with the kit bolted on and no tuning?
