???What would you rate this setup???
Old Sep 23, 2004 | 08:19 PM
fast350camaro's Avatar
I called powerdyne today and I told them that I had a 95 z28 with the 4.5lb supercharger, agresive cam, headers, intake, ignition, and that it has been slightly bored but I don't know how much... The problem is that the car is only showing it to be boosting at a little over 1lb :-( They told me to change the pulley out to a 6lb and change the crank shaft pulley to a 7.0" He said this would give it a solid 6psi of boost... and would be safe on a 10:1 compression ratio... Does this sound like a safe way of doing it or should I just stick with the 4.5lb pulley and change to a 7.0" crank... "he said that if I did this and not the pulley to I would only gain 2 maybe 3 psi of boost.. Any info would be GREATLY appreciated.. thanks,
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
