Whats the highest boost I can do a 355??
I might go with a 355 build up. I wanted a procharger. I wanted to reach maybee 700 rwhp with a procharged 355. How much boost should I go with to get there. I want the car to be a reliable dependable car. I dont drive the car every day. Maybee 15 -20 minutes a day the most. - Mike
Re: Whats the highest boost I can do a 355??
Originally Posted by detroit1994z28
What about 15 pounds with a 355 with canifield heads and a nice blower cam - should that do it- MIke
Get a D1 SC. You will see rwhp close that with an M6.
Rich
addendum: should say "it's possible". Not many 700rwhp cars are out there. But it can be done.
Rich
Rich
Rich
Rich
Rich
Originally Posted by Josh-'97 WS6
Even assuming a 100% power gain on a blower-oriented 355, he would be off nearly 100 rwhp from his "goal" of 700 rwhp, probably more. Unless he wanted to dip into race gas, serious intercooling (not ATIs twin setup that comes with the D1SC), and/or water/alcohol injection.
Anyway, a specific hp goal is not something I would advise. Decide what you can spend and then get the most you can for that amount of $$$.
Rich
What about 600rwhp. On a 355. with 15 pound procharger with the right heads and cam can it be done. I'm debating to go with a 15 boost procharger on a 355 build up, 383 stroker or 396 stroker. I cannot make up my mind. I just want to go the cheapest way to reach my goal but still stay on pump gas and dependable
Rich- I agree with you 100% . I was just pointing out that he won't reach 700 rwhp on a 355 on pump gas @ 15 psi, as he had suggested. I would think that he would need to see 18-20 psi to reach his goal?
Speaking of beefcake rwhp numbers, anything new on your car Rich?
Rich
Okay I have only 10k to spend for a motor build and 15 pd procharger
Rich
I was just gonna take my 94 camaro m6 to a shop and have this all done. They told me they would give me a 12bolt rearend,clutch, 396 stroker, 15 pound procharger - labor,parts,and all - roughly 15k. So basically thats my plan. But for a 355 build up with a 15pound procharger - I think would be cheaper and give me what I'm looking for. I'm bascially going from a stock motor with a hot cam and bolt ons to something more intense. Whatever I decide to get I'm defently getting a procharger with a high boost like 15. I'm sure I will be happy with that. Mike Fortuna selling his 93 camaro on this site. he has a 355 with 10 pd boost and is running a 10.94. So either a 396 or 355 I will go with. I just want soemthing with allot of rwhp that can get me into the mid -low 10's something for the street. - Mike
Also my stock 10 bolt rearend. If I were to put drag radials on it and only really race from a roll without dumping the clutch at 6k. Do you think my rearend will hold up for a summer or so. I dont plan to dump the clutch at a dead stock at 6k. Just mostly from a roll I will gradually put the pedal down.
