Turbo charger with hot cam
Old Nov 22, 2004 | 01:36 PM
detroit1994z28's Avatar
Just came to mind how would the lt4 hot cam work with a turbo charger. Since both start to kick in at top end??
Old Nov 22, 2004 | 02:12 PM
Avengeance's Avatar
Re: Turbo charger with hot cam
Hotcam is a 112lsa correct? From what I understand turbo cars dont like a low LSA, hinders spool up.... I have a 114lsa TR224 and I was wondering the same thing cause Ive been contimplating turbo as well, I heard my 114lsa is "riding the fence" as far as compatibility for turbo.
Old Nov 22, 2004 | 09:30 PM
texlurch's Avatar
The HC works ok, but isn't the optimum for a turbo setup. It would be better suited to a S/C. At least that is what most cam grinders have told me. I made 405/513 at 6 psi with the HC on a stock motor, with my JY twins. So it WILL work, but your probably leaving some power on the table.
Take a look on Competition Motorsports site; they have numerous turbo and s/c specific cams listed, and you will notice that they have totally different specs.
And turbos don't "kick in on the top end", that is more like a S/C curve.
Old Nov 22, 2004 | 10:42 PM
engineermike's Avatar
112 shouldn't be considered low LSA. Most articles say to use 112-114 LSA for turbo, whereas NA would require 104-108.
The problem maybe the duration split. Most turbo cams are single pattern or reverse split. The Hot Cam may work with a well designed header and high A/R turbo since that would reduce backpressure.
BTW, I don't really consider a turbo OR hot cam to be top-end. Both come in low in the rpm range as compared to a CC306/centrifugal.
Mike
Old Dec 18, 2004 | 11:03 AM
LT1ponykilla's Avatar
Mike
I have read some of your posts about turbos on LT1's and you seem to be pretty knowledgeable with things. I have the XE 224/230 cam on a 112. I know this isnt a good forced induction cam but do you think it would be ok? My buddy had the same cam but he was running the Vortech S Trim on 6 psi. It pulled really well!
Old Dec 18, 2004 | 11:53 AM
The 224/230 - 112 is a very good blower cam, though most will disagree. However, there was a Procharged Z28 a few years back with 355 cid, ported LT1 heads, ported intake, 18 psi boost, and a 224/230 - 112 cam that pulled 147 mph in the quarter. Just be sure to use 1.6 rockers and/or a high-lift intake lobe.
Old Dec 18, 2004 | 12:07 PM
Sevendustx1's Avatar
Hot cam works very good. I have one myself pulling great numbers on the dyno. Maybe its not the best cam for a turbo but its defiantly not the worst.
Old Dec 18, 2004 | 01:33 PM
thanks man! my friends car ran very good with that cam. 6psi felt like it was alot faster than 100 shot of nitrous!
Old Dec 18, 2004 | 05:08 PM
CamaroSS30thAnn's Avatar
kinda out of line but , i am interested in the hotcam and a S/C, how good will a stock motor hold up to the S/c at about 6psi or less...how long will it last and what may be a close guess of RWHP with hotcam headers and S/C at 6psi
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
