Pushing the limits, need advice.
Old Nov 15, 2004 | 02:43 AM
Sneakin Deacon's Avatar
im getting a methanol injection setup soon. and was wondering if i would be ok in turning up the boost a few more psi...i am currently running 6-7psi on a S-Trim'd bone stock LT1...stock heads, bottom end, cam, manifolds, everything (minus blower, injectors, fuel pump)
as long as i avoid detonation the motor should take 10-12psi correct? im only planning on running 15deg or so of timing, and use the meth kit to put me around 11.5:1 A/F. rought estimate would be ~450rwhp
if i am totally off base on this its ok, just let me know. my understanding was that detonation and the pressure spikes they cause were what damaged things.
Old Nov 15, 2004 | 07:30 AM
rskrause's Avatar
Moderator
Re: Pushing the limits, need advice.
You are off base. At one time I had a 6psi Vortech on an otherwise stock LT1. Ran fine for nearly 10,000 miles. Added water/alcohol injhection and upped the boost to 10psi. It lasted <500 miles in that configuration. Don't do it.
Rich
Old Nov 15, 2004 | 07:54 AM
what gave you problems?
Old Nov 15, 2004 | 08:27 AM
rskrause's Avatar
Moderator
The pistons were "terminated with extreme predjudice".
Rich
Old Nov 15, 2004 | 01:31 PM
dreamer1q's Avatar
Thats one way to say it
Old Nov 15, 2004 | 02:03 PM
but was it detonation that caused it or what? can the stock pistons just not handle the cylinder pressures?
Ericksd
Jan 20, 2016 06:07 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Sep 11, 2015 09:44 AM
