Help with intake ducting ideas...
Old Oct 25, 2004 | 09:11 PM
kmook's Avatar
Advanced Tech Moderator
Well i know this isnt for a forced induction car but i know you all have to deal with routing/making intake pipe soooo
I have a custom intake manifold for my LT1. My problem is the throttle body sits about 2 1/2-3" inches higher than the stock TB. So i'm trying to figure out what i can use to connect the TB to the maf (stock location to) since the stock elbow wont reach because of the angle/curves. Does anyone have any idea on what i could use to make this? Thanks.
Old Oct 25, 2004 | 11:34 PM
Bud M's Avatar
Re: Help with intake ducting ideas...
Maybe this will help?
http://www.bakerprecision.com/silicone.htm
http://www.autospeed.com/shop/category_1676/browse.html
Old Oct 25, 2004 | 11:50 PM
kmook's Avatar
Thanks, I should be able to get whatever i need from one of those.
Old Oct 25, 2004 | 11:51 PM
mongse_1's Avatar
Any pics by chance? What shape is the new throttle body? Oval like the factory or round? I'm just not seeing why the a slight angled piece of tubing fitted into the intake tract won't cure the problem.
Old Oct 26, 2004 | 12:02 AM
kmook's Avatar
Well the damn area is so crampt i'm having to work with. Basically everything is the same as stock except raise the TB about 3 inches. For example you could just angle the stock intake elbow at an angle upward to the TB but in doing so the end that goes onto the TB will be angled and not be long enough... get what i mean.
Sorry no pictures... unless you want me to draw something in MS paint that looks like a 4 year old made it
Old Oct 26, 2004 | 12:07 AM
mongse_1's Avatar
I can relate to a 4-yr old mentality quite well.
I get what you're saying. The oval throttle body makes everything so much more complicated. Would you have enuff room to raise the rest of the intake tract up the 3" required to hit the throttle body? You can add that into the piping that comes up through the hole on the driver's side (assuming you are running it that way and are using metal tubing).
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
eanhl2004
Apr 4, 2015 12:01 PM
Brake_L8
Jan 20, 2015 09:44 AM
