How do you drive?
Old Nov 13, 2004 | 09:15 PM
Alvin@pcmforless.com's Avatar
How do you drive?
Guys, how are you driving your car at the track?
What tires are you using?
The reason why I ask is because on the 10# aftercooled setup I can launch the car pretty good (2.0's on street tires) but it would start spinning the tires at about 5k in first..
Now that the car has 15#'s it does the same thing in second from 4000rpm and up. It will even do it with less than full throttle on the street from about 45+ which is my next question..
How are you behaving on the street with 500+rwhp?
Old Nov 13, 2004 | 09:26 PM
rskrause's Avatar
Moderator
Re: How do you drive?
This is why some people will say that ">xxx hp is useless on the street". You can't really hook up that much hp in the lower gears once the boost really kicks in. When I had a T56 if the nitrous were on it would spin pretty good at 85-100mph in 4th gear. Quite a "thrill" if you weren't ready for it.
Rich
Old Nov 13, 2004 | 09:31 PM
quite right..
reinforcing my idea of buying anthor car to safely bracket race (mid-low 12's).. this things too damn out of control.
Old Nov 14, 2004 | 12:25 AM
MEAN LT1's Avatar
Originally Posted by ROOSTER93V8
quite right..
Sweet isnt it?, I cant wait to spin the tires at 60mph
Old Nov 14, 2004 | 11:43 AM
streetbad's Avatar
Better tires. Drag radials at least.
Old Nov 14, 2004 | 07:16 PM
marshall93z's Avatar
definitely try some drag radials...not nittos either!
Old Nov 16, 2004 | 02:55 AM
sleeperz28's Avatar
yes it all depends on how the car is setup..I think mine is setup pretty good. In warmer weather I can launch my car from a dig and not have problems baking the tires
Old Nov 16, 2004 | 05:53 AM
rskrause's Avatar
Moderator
Well, you must have some sort of very sophisticated boost controller. How do you do it?
Rich
Old Nov 16, 2004 | 12:01 PM
1st and goal's Avatar
quite right..
Hence the reason I have two Z/28's
I have a set of Nitto Drag Radials that I'm using for street tires on my 94 (had them as drag tires on my old setup and converted them as full time street tires as the Goodyears were dead) and I raced it once on those and it was a waste of time...I couldn't go full throttle till about 80 mph and ran high 11's at 128, went back up two days later with my Hoosier QTP's and was running low 10's @ 135
Klypto
Mar 23, 2016 09:05 AM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
