Head gaskets
Old Nov 23, 2004 | 05:12 PM
blown69nova's Avatar
Head gaskets
Does anyone have any PERSONAL experience with copper head gaskets/o-rings? My turbo buddy swears by that setup but I'm concerned that it will not seal coolant etc. well enough for street use. His theory is that when people advise against their use they always say "I know a guy" then tell you they leak! So any experiences you can share would be very helpful.
My next question is, are any of you guys using Cometic MLS gaskets with boost in the 15-20 psi range with success? I blew two head gaskets with 8 psi (with high mile L98) this past summer and don't want to deal with that again! Thanks for any info, Steve
Old Nov 23, 2004 | 07:52 PM
Jeff 96 SS's Avatar
Re: Head gaskets
I know a guy and its me I'll never do it again I have never been able to get them to completly seal I have it to the point where it just seeps under boost not very noticable unless your on the dyno their is always a small puddle under the car when i take it off the rollers. Go with the Cometic gaskets they will hold big boost.
Jeff
96 SS BLOWN
96 TA 396 D1
Old Nov 24, 2004 | 06:08 PM
john35thss's Avatar
Re: Head gaskets
All I can say is DON'T DO IT I ran copper two years and 20000 km resealed heads twice changed gasket once tried silicone hylomar I finally got the coolant under control by running purple ice and water with GM tablets.
Still weeps oil from china rain between head and block after about 20 hot cold cycles.
Have friends running 15 pounds with no leaks using felpro 1074.
Now building another short with another engine builder that is not o ringed. The reason I did it in the first place, recommended by ARE (thanks)
John
Old Nov 26, 2004 | 01:21 PM
sleeperz28's Avatar
Re: Head gaskets
Im making 1200hp with cometic head gaskets. Im sure the felpros will do just fine as well. And yes this is an LT1 motor with just head studs
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
