pb600 vs s-trim
Old Nov 15, 2004 | 07:33 PM
sleepybu's Avatar
pb600 vs s-trim
-which is better?
-what times have you guys run with these blowers
thanks
Old Nov 15, 2004 | 09:43 PM
engineermike's Avatar
Re: pb600 vs s-trim
LJ's run 9.9x at 139.x with an S-trim.
Old Nov 15, 2004 | 10:11 PM
badblackta's Avatar
Re: pb600 vs s-trim
well i destroyed my built tranny after running the car for maybe 5 min with a p600b. car didnt even hook. so it might be puttin down a little power
Old Nov 16, 2004 | 01:28 AM
sleepybu's Avatar
Re: pb600 vs s-trim
you guys running ic's
Old Nov 16, 2004 | 02:47 AM
Hoostie's Avatar
Re: pb600 vs s-trim
Procharger is the only way to go.
Old Nov 16, 2004 | 05:43 AM
z28draco's Avatar
Re: pb600 vs s-trim
vortech all the way...
Old Nov 16, 2004 | 01:45 PM
Sparkz28ss's Avatar
Re: pb600 vs s-trim
I like my p600b..
my friend has the same setup as me...
355ci Lt1 ...same bottom end...but he has CNC heads,mine are hand ported..
he has a .510/.510 lift cam..and I run the hot cam..he runs 10psi from his S-trim..I was running 6psi last time we ran.....and I yoinked him hard..I have a vid of it somewhere..
Old Nov 16, 2004 | 04:48 PM
Re: pb600 vs s-trim
I saw a test about 8 years ago comparing a 6 psi S-trim to a 9 psi intercooled P-600B. The 9 psi blower took more hp to drive it and it heated the air more. By the time you factor in the losses through the intercooler and the added parasitic drag, the S-trim made more power.
Old Nov 17, 2004 | 01:36 AM
sleepybu's Avatar
Re: pb600 vs s-trim
i haven't seen any quick cars (fast then 11s) with a pb600. There are a few local 5oh guys going 9.90/80s :blah:
Old Nov 17, 2004 | 06:12 AM
z28draco's Avatar
Re: pb600 vs s-trim
5.0's are lighter than most fbodz and as engineermike said "LJ is doin 9.9x...with an s-trim" in an fbod.
Old Nov 17, 2004 | 11:51 PM
carnutz's Avatar
Re: pb600 vs s-trim
LJ and a S trim? I was pretty sure its a YS or YSi trim..... FWIW I think the P600 is a bigger head unit CFM wise. I have one of each, the P600 tensioner set up sucks, the Vortech has a nice tensioner but seems to make less power.
Just my .02 worth.
Old Nov 17, 2004 | 11:55 PM
Re: pb600 vs s-trim
LJ ran 9.9x with an S before switching to the YS.
Old Nov 17, 2004 | 11:59 PM
carnutz's Avatar
Re: pb600 vs s-trim
I didnt know that, cool.
I stand corrected.
Old Nov 18, 2004 | 06:00 AM
IDOXLR8's Avatar
Re: pb600 vs s-trim
I have owned a P600b and would highly recommend a Vortech S-trim over it.
Old Nov 18, 2004 | 11:46 AM
sleepybu's Avatar
Re: pb600 vs s-trim
i c
