sts turbo on a stock engine how long will - --
Old Dec 6, 2004 | 03:28 PM
detroit1994z28's Avatar
If I were to put a sts turbo kit on my stock lt1 engine how long will it last before a rebuild??? - How much boost would you run till a upgrade??
Old Dec 7, 2004 | 08:46 AM
Geoff Chadwick's Avatar
Re: sts turbo on a stock engine how long will - --
I wouldnt run more then 6psi personally. 8psi maybe...
How long before a rebuild? Do a search. This is covered in a million threads. Could be 30,000 miles, could be 500 miles. Depends on the tune, how you drive it, and the condition of the motor.
Old Dec 7, 2004 | 02:58 PM
trtturbo's Avatar
With a good tune, 5 psi is pretty safe. Doing forced induction is always a risk. If there is an issue, it can destroy your engine. There are many people who run 8,10, even 12psi on a stock engine. I personally have mine just set at 5psi. I am adding a FMIC and injectors and will run 7 or 8. Thats it for my otherwise stock engine. Also keep in mind that with the STS, anything over 5 or 6, you really need to do meth or intercooler.
LeftoverChinese
Jan 14, 2024 03:03 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 12, 2014 10:51 PM
