Post pics of blow off valves..
Re: Post pics of blow off valves..
Here is a pic of my HKS SSQ BOV with an aftercooler. I am running the stock bypass valve now.
http://pg.photos.yahoo.com/ph/hughla...e4.jpg&.src=ph
I won't recommend doing this though. It was a waste of money and time really. It may be better with moving the MAF. Anyhow, with the BOV it creates a tiny bit of surge while coasting. Secondly, you can't hear it unless you get over 6 psi of boost. Plus with everything in the car, this sound isn't doing much. The other guy, shouldn't be hearing your BOV anyhow but seeing your tail lights
If you need something better than the stock bypass valve then I would recommend going to a mondo bypass valve.
Ok, back to your post.
cheers
.If you need something better than the stock bypass valve then I would recommend going to a mondo bypass valve.
cheers
95chwagon
Jan 13, 2015 09:19 PM
