Need Blower cam for 800 RWHP Combination
Old Nov 24, 2004 | 04:05 PM
kenny1man's Avatar
All Cam GURU's...Need Blower cam for 800 RWHP Combination
What would be the smallest hydraulic roller cam for the combo below. Looking to get 800 RWHP (streetable - 40 mile to/from track with air conditioning). Looking to run high 8's in full street trim.
This is not an LT1. It was an L-98. I'm using a World block with Trickflow R-series heads in my 88 camaro.
383 Scat Crank/Billet I-beam Rods
8.5 compression
TEA Ported TrickFlow R series heads Flow 305/248@550 and 310/258@600 Lift - Yes these numbers are correct. 218CC
Vortech YS@20-22 PSI with race gas at track and 14# for street
TEA Ported Holley Stealth Ram intake with 1400 CFM Monoblade
83# Injectors
Accel Gen 6 DFI
1 7/8 Custom Headers
Dual 3in Exhaust
3.42 gears
T-400 tranny w/3800 converter
Old Nov 24, 2004 | 05:45 PM
engineermike's Avatar
Re: All Cam GURU's...Need Blower cam for 800 RWHP Combination
What you're doing is a bit beyond what most here know about. 99% of the time you will get the 224/236-114 recommendation.
My advice to you is to find out what the Renegade Mustang guys are doing. They have similar combo's and are running mid/upper 8's at upper 150's mph using hydraulic roller cams.
Mike
Old Nov 24, 2004 | 06:08 PM
kenny1man's Avatar
Mike
Mike
That's exactly what TEA recommended I do. Brian also mentioned using a "Renegade" grind cam, but the lift is only .550 and I thought it was a little short for my hi flow heads. Many people have their philosoply on short lift vs high lift cams when It comes to FI. I guess i'll have to do a little more research before I decide. The problem is most people that make that type of power are very secretive about their cam specs, as well they should I guess.
Old Nov 24, 2004 | 09:40 PM
97WS6SCharged's Avatar
Re: Need Blower cam for 800 RWHP Combination
Sent you a PM.
Old Nov 28, 2004 | 12:31 AM
Highlander's Avatar
Talk to BRET. sstroker ace
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
