Sts dyno numbers
Old Oct 31, 2004 | 09:18 PM
2ktransam's Avatar
Sts dyno numbers
Here is my dyno run on 5.5 lb and everything that is in my sig. The lower pull is my h/c package pull on the same dyno before I installed the turbo. I have a NA cam right now so my numbers could have been a good bit better. You can view my dyno sheet at
http://my.starstream.net/f8lpony/Pho....5psi%20sm.bmp
Old Oct 31, 2004 | 09:33 PM
badblackta's Avatar
Re: Sts dyno numbers
nice numbers man
Old Oct 31, 2004 | 09:46 PM
MEAN LT1's Avatar
Nice numbers man, a little shakey up top though ehh?.
Old Oct 31, 2004 | 09:52 PM
2ktransam's Avatar
Yeah, My fuel pump was struggleing as soon as it hit boost.
Old Nov 1, 2004 | 03:20 PM
sherwinZ28's Avatar
So you're saying you threw on the STS turbo system on your 112LSA cam?
I have a 230/236 heads/cam on my car right now but didn't want to throw on the STS sytem due to people telling me it won't work properly with that cam. I believe my cam is also 112 LSA. I had a good deal on the package as well but skipped it.
What is a good cam for the STS setup? I've been thinking about switching over to that since it's easily smogged in Cali(not that I can pass smog right now).
Old Nov 1, 2004 | 03:36 PM
Alvin@pcmforless.com's Avatar
very nice
Old Nov 1, 2004 | 05:54 PM
5.0THIS's Avatar
When you planning on getting some track times with it? Post up when you do. Nice dyno numbers.
Old Nov 1, 2004 | 06:02 PM
96TurboTA's Avatar
Not bad. Is that the base STS kit? I see spool/max torque is around 3800rpm.
Old Nov 1, 2004 | 07:29 PM
F8L Z71's Avatar
On the LS1 motors, especially a 5.7L the 226dur cams seem to be somewhat popular.
I'm running a 226/220 .591/.554 116 cam in my 5.3L truck.
I think some of the bigger cube guys are using 336/332 high lift cams.
Old Nov 2, 2004 | 12:07 AM
5.0THIS's Avatar
Did you mean 236/232? If not I've never seen such a cam.
Old Nov 2, 2004 | 09:21 AM
F8L Z71's Avatar
DOH! Total typo! LOL
Old Nov 9, 2004 | 11:39 PM
2ktransam's Avatar
Yeah I threw the STS kit on with the 112 lsa cam. It works really well but I think a good turbo cam would help it out. Don't let people tell you that the kit won't work with your cam, it just won't be at the top of its potential. I have a big turbo cam that I am going to put into it but I blew a head gasket so it will be a while before I have any new numbers for everybody.
Old Nov 9, 2004 | 11:40 PM
2ktransam's Avatar
All of the tracks are closed around here and I blew a head gasket so I am hoping to put up some good number in the spring.
Old Nov 9, 2004 | 11:52 PM
2ktransam's Avatar
This is the upgraded kit with the gt67 turbo. I did the upgrade to get more power up top with my head and cam package. This kit really spools quicker on the street than on the dyno and the lag is not really noticable on the street.
Old Nov 10, 2004 | 04:24 PM
sherwinZ28's Avatar
Great, thanks for the information !
