View Full Version : Drivetrain
- Master Cylinder shaft isn't long enough?
- 1995 z28 M6 Vibration when first moving
- 1995 Z28 4L60e Band Slipping -Longer Pin Fix???
- Needs a Clutch Kit
- 1998 z28 Camaro driveshaft help
- '96 T5 Hydraulic Clutch Line Replacement
- What can i do to a stock 1995 camaro z28
- Noise in rear differential
- New clutch, releasing at the floor.
- Bad Throw Out Bearings
- 1993 z28 4.10 VSS question
- 1994 4l60e in a 1997 z28
- 1995 t56 fluid
- 5 channel rear axle
- Eaton TrueTrac Oil, What are you guys running?
- DTC 82 transmission code can't remove it
- Moser 12bolt into 1995 Z28 Install
- Need differential diagnosis info
- Transmission not shifting in my 94 Z28!!
- 99 TA - Axle Shaft Installation Issues
- Shifter loose 96 Z28
- Strange 12bolt ABS Sensor Repair
- Clutch grab?
- Question about working of Solenoid control
- 2.73 to 3.42 gear questions
- 1995 Formula piñon seal leaking
- Transmission Install
- Big Cam/stock stall
- Stock Shifter?
- Noise coming from rear.
- Help on swap from T56 to 4l60E
- '95 Z28 4L60e in 4thOD and Park/N flashes Mode A&C with Timing 45 to 0
- Minimum Lift Clearance To Pull Transmission?
- Serpentine Belt Tensioner Assembly for 1LE
- Help with Building a 700r4
- Is the 4L60E really worth it?
- I’m buying a new clutch need info.
- ***Holiday Update*** GIVEAWAY!
- Cost and labor worth it to restall 3200 to 3600
- Auburn Rear?
- Master/slave cylinder assembly # 174-1072
- 94 camaro z28 t56 problem
- Clutch troubleshooting
- 700r4 k case input shaft spline count
- 1995 z -28 tranny slipping
- Pump help
- Clutch Options
- PerformaBuilt customer with Black edition 4l60e showing off at dyno
- Live L3 Performabuilt l3 build
- PerformaBuilt Transmissions’ Holiday Transmission Giveaway!
- Car rolled back while in drive on incline and other issues
- 96 Z won't go into gear
- Strange Dana 60 - what grease for zerks on axle tubes
- LT1 Clutch
- LT1 clutch fork disengagement issues...please help!
- 3rd Gear Wall at WOT, Clutch Hydraulics, and Drill Mod
- Performance Rear End Ratio
- T56 Fluid change
- Fluid change Rear end.
- Stumped... Trans or torque converter or neither?
- LT1 T56 and long crank 6.0 LS
- 96 Z28 broken clutch fork
- Check out our super chevy artcle thanks
- Clutch Chatter
- PerformaBuilt Holiday Giveaway is back see inside
- Vibration on engine rev
- T56 experts/help
- Pros/Cons Going to 3.73 w/T56
- Horrible noise from bellhousing.. oh man
- 1 Year Tear down and inspect live of Performabuilt Black Edition 4L60E
- Key lesson learned in LT1 clutch replacement
- Underdrive pulley question
- Help...change tps now high idle and shift off
- 1994 Z28 TCC issue
- Do my axles look re-usable (fourth-gen 10-bolt)
- reverse issue with my T56
- Finally, 3.73's in!!!
- Rear End Shop Stumped - Help me help them!
- Shifting problems. PLEASE HELP
- 12 bolt - 4 Channel into a 3 Channel Car
- Borg warner t56
- 78 z28 rearend conversion
- slave cylinder
- Anyone have any suggestions?
- What Brand of Bearings?
- Strange Noise....Need Some Input Please!
- Rear Axle Question
- 95 z28 10 bolt rebuild.
- 1997 z28 30th anniversary will not move while in gear
- 1993 Z28 Transmission Problem
- 1994 z28 need help with transmission
- Trans tune question.
- differential fluid change
- oily water/antifreeze in 97 C- 3.8 engine
- Clutch Recommendation, 97 SS
- 4l60E late shift
- TV cable-Late shift
- Differential swap question
- 1996 z-28 rear end clunk
- Clutch and transmission install
- Transmission Question
- Horseshoe shifter for 69 camaro
- 1996 as with 1le drive shafts need Universal Joints
- First to second gear strange hits
- Hurst shifter
- 1993 Z28 TV cable length from the factory
- Bolts stuck on bell housing
- 4L60E Delayed 1-2 Shift
- precision gears vs motive gears
- Clutch disk question
- clutch install question
- How to calculate for the correct stall?
- Eaton Posi / Mosier 12 bolt Service
- McLeod Master Cyl, LT1 T56 .. can't get it to bleed! :(
- T56 doesn't go into gear
- 2000 Z28 throwing code P1860
- Pinion Yoke Alignment Question!
- 4l60e issues
- Strange Dana 60 leak issues
- 3.73 Ring gear mfg identification
- Technical Question???
- 94 Trans Am Manual Tranny issues
- Strange Noise Under Gear Selector?
- 95 transmission with 24x conversion
- Clutch decision
- 4l60e trans. filter and gasket
- Pinion preload
- Power steering not working at idle on 97 LT1
- Is this piece required????
- Need some info on Shaft Slip Yoke
- 4L60E Question.....
- T/A 10 bolt girdle cover bracing?
- Need evaluation of rear gear pattern
- 4l80e front pump seal
- Can you interchange gears between the M29 T56 and MN6 T56?
- Looking for clutch recomendations T56 LT1
- rear axle width
- I think my clutch just packed it in
- Stall Converter Choices!
- Rear Ratio
- Differential Fluid
- Rear end swap
- Tranny problem?
- Smacked on rear brake rotor to remove now problems
- How To convert to 4L60E \ 4L80E ..Instructional vid
- 1994 LT1 4L60E into a 1995 LT1 question
- Clutch preferences
- Performabuilt Holiday Giveaway !
- PerformaBuilt Black Friday Deal
- 6 spd started shifting hard
- 350 transmission
- 4l60e front pump and TC
- What to upgrade on my 4L60E?
- Grinding t56
- LT1/T56 conversion to push style clutch
- LT1/T56 clutch Fork.
- '95 Z28 Automatic Trouble Shifting into 3rd at High Rpm
- Clutch install
- Slipping
- Bouncing Speedo, Constantly Shifting
- 1995 z28 4l60e swap?
- Transmission grinding
- Where to buy a new rear end
- 2002 vibrating driveshaft
- What is wrong with stock shifter T56
- shifting problems after installing a stall converter
- 1998 Z28 rear end in a 1999 V6 Camaro
- 95 roadmaster trans work in a 95 f body?
- Automatic Transmission wont go into any gear
- Track Gear Ratio
- trans, again
- Trans 4l60e
- Car wont shift to second at WOT
- TCC lock and unlock mph settings 4L60
- 95 4l60e
- so im told my car is in limp mode
- 78 z/28 th350 to PG
- No Reverse 2001 SS
- whining sound when turning
- Transmission Stuck to Bearing?
- 93 4L60 Trans Pan Harness
- 6 speed, loud wine in 5th 6th gear! audio included
- Trans rebuild
- 12bolt questions
- Replaced broken slave cylinder. Clutch not going down to floor.
- Torque converter drive
- 0-60
- 10 bolt rear end drain plug size?
- 67 Factory traction arm question
- Transmission service??
- gear ratios
- Noise from Clutch/Transmission
- When checking/setting pinion angle...
- Is a special scan tool needed to bleed brakes?
- I want to free the slave master!
- 1993 camaro z28 best clutch for street
- 95 camaro z28 flywheel weight?
- tranny or torque converter? Or...?
- My gears are somewhat rough to switch
- 1996 z
- New Gears & LSD
- Vent Tube on Tranny
- 20's
- 2000 z28 rear end 3.42
- Automatic to 4 speed conversion
- driveshaft ? u joints ? rear end?
- creaky clutch
- Trans or rear end?
- Phoenix tranny shops?
- Alot of chatter and slipping
- second gear
- Aluminum Flywheel with Mcleod Street Twin?
- rear end swap
- Stall Converter
- 4l60e tune up
- 4:33 gear or 4:56.. i have done some research now looking for real world
- Trans issue
- Transmission uncertainty
- Clutch Failure - Has this happened to anybody?
- LT1 Tcc Lockup Question (tune related)
- PerformaBuilt Holiday Giveaway is back see inside for details
- Car doesnt shift into second
- TCC solenoid and harness...can't find
- spinning sound
- Transmission fluid
- LT1 Clutch Fork Hits Pressure Plate... Why?
- Need Transmission help really bad!!!!
- 4L60E Shift control lever, part unavailable. Options?
- T -56 problem
- Any of you running a faceplated T56?
- cruising in overdrive converter unlocks?
- Gears
- Tranny issue?
- Introducing the new performabuilt black edition 4l6xe series
- Transmission Advice
- Starter or flexplate problem 94 z28
- 4L60E: 2.73 to 3.42 conversion opinion
- 95 z28 brake and abs light
- frustrated
- 400 driveshaft
- Turbo 400 in a 95 lt1
- shortened 3" each side
- T56 into a 700R4 Third Gen
- After 3.73 gear install, gears whine after warmup
- Won't downshift
- Time for a new clutch (LS1)
- yank ss3200 or ss3600?
