Underdrive pulley question
Old Jul 28, 2017 | 12:46 AM
97TAMONEYPIT's Avatar
Hi all, I had a BBK under drive pulley put on when my crank hub was redone, with the correct new belt. Seems like it idles lower when off the gas, like going around corners. Almost seems to stall, but it doesnt, just drops real low idle, then catches itself. Or if I'm going, then comes to red light, I feel like I need to keep foot on gas a little to keep idle up. If I let it just idle, it idles down real low, catches itself, and idles back up....it was the first time I've really driven it in close to 6 months, just curious if the under drive pulley would affect this, or something else, like needing throttle body cleaned....? Thoughts? Thanks in advance
Old Jul 28, 2017 | 10:18 AM
Chimera96's Avatar
Re: Underdrive pulley question
your IAC may be sticking
underdrive pulley won't affect idle rpm
Old Jul 28, 2017 | 03:00 PM
Then there's the question.... is a gain of 0.7 peak HP worth it?
Drivetrain Modifications #2
Old Feb 16, 2018 | 01:46 PM
Just to answer/close this thread, replaced IAC per Chimeras recommendation, clean throttle body, reset battery, fixed issue. Idles fine now. I believe the IAC was the issue, being dirty.
Mortify
Jul 27, 2007 01:36 AM
miiso11
Jul 13, 2005 09:58 PM
red96z
May 29, 2005 08:47 AM
MeanZ687
Mar 25, 2004 05:26 PM
gsdz28
Jan 11, 2004 07:18 PM
