PDA
View Full Version : Fuel and Ignition
Pages : 1 2 3 4 5 6 7 8 [9] 10
  1. Weatherpack MAP Sensor Plug
  2. Plugs and wires
  3. cleaning the fuel injectors/system
  4. Fuel Pump Failure
  5. LS1 stock injector size?
  6. 90 degree, or straight boot
  7. fuel injector cleaning
  8. F.A.S.T. LT1 Injector question
  9. No Spark
  10. Aftermarket fuel pumps, install problems?
  11. Fuel pump and BLMs... >.>
  12. Big Idle and running problem!
  13. New fuel pump question...
  14. how to clean fuel injectors
  15. LS1 type replacement ignition for LT1
  16. How can my car require 4 major repairs at the same time?
  17. 1997 Fuel sender options
  18. Running rich, will my fairly new 02 sensors hold up until the new dyno tune?
  19. opti
  20. Need help finding the right spark plug between these two...
  21. stalling problems??
  22. junkyard injectors
  23. fuel pump
  24. Opti??
  25. NGK-TR55's
  26. Starter Problem
  27. Racetronix part number verification please.
  28. Best alternator to use?
  29. Anyone running the A.P.E Walbro hp 255lph pump?
  30. Car has gone nuts!
  31. Installed $70 TRE 255lph Fuel Pump - Review
  32. opti sputtering
  33. fuel pressure questions???
  34. No power?
  35. Car Won't start
  36. Injector issue?
  37. unstable BLMs
  38. MSD pro billet distributor question
  39. Clogged fuel filter?
  40. fuel problem....I think?
  41. timing control
  42. fuel pump hotwire kit connection
  43. dynaspark?
  44. fuel injector problem
  45. Racetronix Injectors
  46. Injector Circuit(s)
  47. GRRR! gettin aggrivated
  48. Can there be too much fuel flow?
  49. new fuel pump
  50. Some direction with lines please :)
  51. Need a new fuel pump
  52. Fuel Pump Fuse?
  53. tune up?
  54. Vacuum line at back of engine
  55. ACDelco Iridium Spark Plugs?
  56. What Ignition?
  57. runs like crap after big puddle?
  58. Fuel pump gone bad
  59. Fuel rail leaking
  60. Fuel Gauge Adaptor.
  61. Has anyone used the fuel line fittings? Quality/Safety?
  62. holley 52mm throttle body 94 lt1
  63. Mallory 685 dead
  64. Walbro install
  65. Fuel pump relay
  66. What all is involved in doing a fuel pump?
  67. How do you know when your fuel injectors are dying
  68. Fuel Pressure Regulator question.
  69. fp/running rich
  70. Fuel Cell with In Line Pump Questions
  71. Does this sound like a dead opti? If so, add me to the club :(
  72. Fuel line mod write up
  73. How do you know if bigger injectors are needed?
  74. warning: optispark!
  75. No more lead after 2008
  76. Fuel fill cutoff / leaks
  77. What will make an injector not open?
  78. fuel problem i think?
  79. lithium on injectors?
  80. External Fuel Pump Question
  81. 180 Degree Boots over wire help??
  82. How many lph fuel pump would the stock 94 z28 have in it?
  83. My ICM cooling mod...
  84. beware accel opti
  85. Help
  86. Air In The Fuel Pump?
  87. Injectors
  88. new,Opti, water pump, FP relay,fuel filter and FPR sill wont run..
  89. fuel pump for a Z28 97'
  90. Are these FMS 36lb injectors?
  91. Closed loop permissives
  92. Stock alternator amp
  93. fuel injector cleaning and flow matching
  94. Fuel issue at high RPM/WOT help debug please
  95. Fuel pump whine?
  96. Powerwire for fuel pump.
  97. Fuel Pressure problems 97 SS
  98. Weird question on gas tank
  99. Fuel lines when doing trap door
  100. ignition box rev limiter
  101. stock fuel pump gph?
  102. Injector testing
  103. DELTEQ plug wires?
  104. Slight Break up between 3,000 and 5,100 RPM
  105. What size hosing to run with my new fuel setup?
  106. advice please
  107. low fuel pressure and bad mileage
  108. Racetronix 255 lph fuel pump-?? hp
  109. Fuel Pressure Problems
  110. Which Of These Coils Would Be The Better '94 Replacement?
  111. Walk me thru some fuel upgrades.. Regulator concerns.
  112. Hole in the fuel __nk!
  113. 3800 SC injectors?
  114. 98 Z28 Fuel Pump Circuit Diagnosis
  115. injection vs carb
  116. Suggestions for Fuel Filters on my LT1
  117. From stock fuel pump to Walbro 255....will I need a AFPR?
  118. Best plugs and wires?
  119. fuel pressure question
  120. Injectors LT1?
  121. What the heck.....
  122. What kind os spray pattern will yield best results on an injector?
  123. Is An AFPR Needed For 36# Injectors?
  124. fuel question
  125. Ecm Or Icm Problem?
  126. keeps stalling?? please help newbe
  127. Converting fuel pump to external mount
  128. thinking of going with Accel adj. FPR, good bad?
  129. accel injector size help
  130. accel injector size
  131. Will I Need To Know My Flow #s For A Mail Order
  132. Diagnosing an ignition problem
  133. looking at buying 255lph pump.
  134. fuel pump bucket
  135. Which Plug Wires?
  136. fuel pump question
  137. How to check fuel pump check valve. ? FP issue.
  138. Injector Size for 500 HP engine?
  139. K&N FIPK Gas mileage question and does tornado work?
  140. Injectors sizes for my mods?
  141. Are these 36# Injectors????
  142. Going from 255lph to 190lph fuel pump?
  143. LT1 Fuel Pressure? Fuel Pump? Opti?
  144. Cleaning inside of fuel tank????
  145. question about RPM limiter "insert" in MSD ignitions
  146. Stock Fuel Injectors 95 z28
  147. What is the Max RWHP on stock injectors?
  148. Spark Plugs to buy?
  149. 255lph fuel bucket installtion questions
  150. anyone ever try this?
  151. underhood fuel line routing
  152. Tell me this is ok
  153. Injectors Part#.
  154. injectors
  155. Hard to start after Walbro pump install
  156. injectors
  157. fuel line quick connect
  158. fuel pump cut out
  159. Precision fuel injectors
  160. Quick fuel pump question...
  161. Fuel Pressure Gauge
  162. ignition boxs MSD 6 vs 7 i don't under stand
  163. 800 dollar fuel pump ??
  164. Running rich please help
  165. ignition help
  166. Can you still buy new 30# SVOs
  167. Can your car missfire if it is running to rich?
  168. no start condition flooding...
  169. Edelbrock inline fuel pump question
  170. Should I go ahead and get bigger injectors?
  171. fuel octane requirements ???
  172. Anyone use one of these pumps?
  173. What Ignition Components are worth upgrading?
  174. Fuel Filter
  175. FINALLY got the MSD in!
  176. what spark plugs to run?
  177. Versa Fueler and injector size
  178. Bad Fuel Pump? But Pump Still Comes On???
  179. When will this become a problem?
  180. fuel pump parameter
  181. 30# injectors enough?
  182. Fuel pump Question
  183. help!!
  184. Is this pressure normal?
  185. Did some fuel pressure testing, fuel regulator or fuel pump?
  186. fuel pump ring won't seat
  187. fuel pump wiring
  188. Who has Walbro 255 In-tank Fuel Pump?
  189. Is this possible on my 96 camaro?
  190. 30# injectors
  191. lower fuel pressure than normal....
  192. walbro255
  193. Running New Fuel Lines
  194. OTVC wire looms/seperators
  195. Still runnin rich
  196. should i change injectors?
  197. 3rd gen. walbro pump?
  198. walbro fuel pump?
  199. Injectors
  200. Car running EXTREMELY lean. Help?
  201. what size injecters?
  202. hard start
  203. Write up on optispark?
  204. How can I test a MSD6?
  205. OTVC question?
  206. pump check valve = dead pump?
  207. New MSD6AL=Wont idle.Please help!!!
  208. Misfire, can MSD6A or the MSD gm single connector coil be going bad?
  209. walbro 255lph pump??
  210. Idle problem
  211. injector cap (FMS 30#)
  212. Is my Fuel Pump going to die?
  213. injector identification
  214. digital 6 mount
  215. msd 6al and ignition control
  216. -6AN or -10AN fuel lines?
  217. fuel pump glue
  218. ls1 28lb injectors limits and fuel pressure question
  219. 375 RWHP guys -- what's your injector duty cycle?
  220. MSD ignition?
  221. Running richall the time
  222. Increasing fuel pressure
  223. Injector popped out of fuel rail?
  224. how bad are bosch platinum+4s
  225. fuel pump????
  226. No spark at coil
  227. Do LT1s have a known problem with excessive fuel pump failure?
  228. plug wires for mid length headers
  229. just to make sure.
  230. PCM Ignition Control (Need to locate B5)
  231. Ignition System Test Connector (need to locate)
  232. lt1 tank/wiring question
  233. Is a smaller aeromotive filter required?
  234. Is stock GM fuel pump good enough for LE2 Setup?
  235. Granatelli 255lph fuel pumps, good bad or ugly?
  236. High compression, should I get an ignition box?
  237. new member with a new question
  238. possible problem with MSD opti?
  239. doing away with the fuel pressure reg.
  240. 4 Day Old Walbro Pump Dead...
  241. aftermarket fuel filter mounting location
  242. dual intank
  243. fuel regulator
  244. walbro 255
  245. fuel pump question (general)
  246. fuel level float adjustment
  247. Delteq and dis-4
  248. Would a 190lph Fuel Pump for a Mustang work?
  249. Low Voltage
  250. fuel system
