Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pump
Old May 15, 2007 | 08:42 PM
finalstage1's Avatar
fuel pump
i have a 1995 firebird that has always ran good . Then last night i go out to start it and all it does is turn over , but wont start . i go look at it today and find out its not getting fuel . i turn the key and the fuel pump does not even come on to prime . i then go hook 12volts to the prime wire next to the pcm and the fuel pump still does nothing . do you guys think its the fuel pump ,the relay , or something else .
Old May 16, 2007 | 09:12 AM
2000GTP's Avatar
The prime wire next to the PCM is supposed to bypass the relay and fuse. I would begin to think you either have a wiring issue, a electrical connection issue, or just a dead pump. I would pull the connector to the fuel pump and confirm voltage at the connector with a multi-meter.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
