Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
low fuel pressure and bad mileage
Old Apr 10, 2007 | 05:14 PM
pattracing212's Avatar
i hav ea 94 lt1 with the mods in my sig. i was having problems with my fuel pressure and bought a new pump for it but have not been able to put it in yet. i was running 28 psi fuel pressure at idle and revving dropped the pressure in my driveway. but then the car will seem fine through normal driving and getting on it in mid rpms. i have no more low end or high end hp or torque. but, while i was driving it, i noticed my gas mileage is worse than it used to be. i only got like 160 miles to a tank. i wasn't beatin on the car either. would the gas mileage get worse like that? i thought it would be better because th efuel pressure was lower? any help is appreciated.
Old Apr 12, 2007 | 07:09 PM
no one can help?
Old Apr 13, 2007 | 03:16 PM
OBE1 95Z28's Avatar
Your PCM is going to try and compensate for low fuel pressure based on the O2 readings. Fix your low fuel pressure issue first (have to replaced your fuel filter?) and then check your gas mileage. A ported MAF may also be part of the problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
