Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
msd 6al and ignition control
Old Mar 6, 2007 | 06:29 AM
RootBreaker's Avatar
Ok so this isnt a camaro... but a pickup... however non computer controlled carbed vehicle.... so like a 78 camaro
posted this on my truck sites but no one has replied... they must not know....
Ok so I got some goodies...
I got
and
now the non automotive electrical guru that I am not needs assistance...
how do you wire these things?
think I need to follow pg 16
GM Ignitions Wiring an HEI 4 Pin Module (Magnetic PIckup Trigger)
however it doesnt show the ignition control
that is on bottom of pg 15
msd 6al manual
http://msdignition.com/pdf/6%20series/6series.pdf
now that im looking...
guess pg 5 of this
http://msdignition.com/pdf/8680_frm%2024828.pdf
Figure 9 Installation to a GM HEI with a 4-pin module (magnetic trigger)
guess the only concern here is the harness pn 8860 and 8861....
I dont remember wires on the side of the distributor that I could plug into like that......
anyone wanna come wire this thing up for me?
goodies are free beer, lunch and this...
Old Mar 9, 2007 | 10:45 AM
mzgp5x's Avatar
I've got those same parts (except 6a) on my 97SS 383 - D1 Camaro. The MSD triggeres from 1 wire. I don't know if you have a point system or a ECM? One signal (12v) pulse should fire the MSD, and, that drives the coil. In the OBD2 PCM Camaro, there is a single coil module which is triggered by a PCM 5 volt pulse, and, that inturn applies 12v to the MSD 6. The 6al has a Multi spark discharge of 3 pulses @ rpm's inder 3K. Those MSD manuals are very good @ diagrams.
Drtryder
Apr 22, 2015 04:17 PM
thenewkid
Apr 12, 2015 07:42 PM
Killer94z
Jan 13, 2015 12:06 PM
thenewkid
Nov 27, 2014 09:41 AM
