Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Opti??
Old May 15, 2007 | 12:20 PM
T-Dubbs's Avatar
Opti??
Car was shutting down, and engine light came on. So I brought it to a mechanic who red the code(s):
1- code 16 (Ignition low resolution pulse not detected)
2- code 36 (Ignition faulty high resolution signal)
He tested the wiring harnesses and determined the distributor is failing.
I was wondering if it could be anything else?
Also, i started pricing out new opti's and was wonder if anybody has used the Accel brand. I'd like to go MSD, but I don't have the extra cash, and thought Accel would be a little better than stock.
Old May 15, 2007 | 01:49 PM
2000GTP's Avatar
It sounds like an opti related problem, especially if the harness checked out. I would stick with an OEM opti, there have been a few complaint threads regarding the Accel.
Old May 16, 2007 | 01:30 AM
mrmint69's Avatar
Msd makes a cheaper version than the pro billet so you can do it for a decent price. I think the price it $150 for the cap and rotor kit. Check Ebay and places like Summit first.
Old May 16, 2007 | 08:53 AM
2000GTP's Avatar
Only problem though is the codes he is getting is very well pointing to the optical sensor portion of the opti. That would go beyond the scope of just a cap/rotor swap.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
