Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
What is the Max RWHP on stock injectors?
Old Mar 28, 2007 | 09:25 PM
Wild1's Avatar
Like the title says. At what point do we upgrade to new injectors (same volume/better made) or larger injectors.
Thanks.
Old Mar 28, 2007 | 09:29 PM
Bersaglieri's Avatar
Injuneer will tell you his formula to figure this out, or you could search for it. I think its around 400hp fly wheel since driveline power loss doesnt mean anything to injectors. If you had to make a guess its close to 350rwhp.
-Dustin-
Old Mar 28, 2007 | 10:48 PM
jimbob65's Avatar
I did 405 SAE RWHP "NA" Stock rear. I was at 97% duty cycle at 6k rpms though...Depends on VE and other considerations (really it's your engine combos BSF that matters).....A stock compression 350LT1 might be maxed at 370-390 rwhp. FI max out pretty damn fast due to higher BSF numbers....
Old Mar 28, 2007 | 10:54 PM
89TramsAmGTA's Avatar
As was stated it will depend on your brake specific fuel consumption and what you consider a safe duty cycle.
Old Mar 28, 2007 | 11:49 PM
seawolf06's Avatar
FWHP x .07 = #/HR
I'm pretty sure that was the formula. Then the stockers are good to about 350 FWHP.
Old Mar 29, 2007 | 12:11 AM
Eh, I think they are good for more than that. Most people are safe making aronud 350rwhp or 400 horse at the motor.
-Dustin-
Old Mar 29, 2007 | 12:16 AM
seawolf06's Avatar
-Dustin-
I think it depends on what kind of duty cycle you're comfortable running as well.
Old Mar 29, 2007 | 12:17 AM
TobyZ28's Avatar
https://www.camaroz28.com/services/calcs/pwcomp.shtml
Old Mar 29, 2007 | 12:31 AM
seawolf06's Avatar
It's very hard to calculate VE, too.
Old Mar 29, 2007 | 12:36 AM
zx1216's Avatar
damn, 405 rwhp on the stockers? I'm dynoing next week so we'll see, i have seen over 100% on mine before and expect 340-350 rwhp.
Old Mar 29, 2007 | 05:56 AM
jasonisdn's Avatar
i was on the stockers at 427 rwhp and yes i was pushing the limit. a little to much but i never had a issue.
Old Mar 29, 2007 | 06:17 AM
Houdini's Avatar
Ran the stock injectors for two years at 390rwhp.
Old Mar 29, 2007 | 07:57 AM
Denny McLain's Avatar
You must have increased the fuel pressure sky high or the numbers are standard and not SAE. Seen 430 rwhp on 28's that had the fuel pressure set to 60 psi and personally made 465 on 30's but 427 rwhp on 24's is a new one for me.
Frankly I like the post that said 370-390 rwhp in a six speed being time to start thinking about larger injectors but I've seen a numbers of cars making 400 rwhp or just a little over/under with 24lb injectors. In the "old days" replacing the injecters was never a thought so that's all we used was stock.
My 97 SS was making in the mid 390 range and the injectors went static around 6000 rpm. When we went to 30 lb injectors it didn't make any more power. In hindsite we probably could have just bumped the fuel pressure up some and the net result would be the same.
Hindsite is usually close to perfect, it's looking ahead that gets a little blurry.
Old Mar 29, 2007 | 08:48 AM
street demon2k3's Avatar
I put down close to 350rwhp and my injectors are maxxed out, but then again I still have the puny 14year old 19#'s from the factory. my car is a 93 so you guys (94-97) IIRC have some slightly larger injectors, and maybe a little more leeway to work with.
Old Mar 29, 2007 | 10:46 AM
truedualws6's Avatar
Waiting for more responses
Well I'm just reading this and hoping for more folks to chime in with their
experience. I'll be installing ported heads and intake, and a set of SLP
shortys soon and will be in same situation. It seems to me that you would
be much better off with bigger injectors running on the low end of the duty
cycle than maxing out the stockers.
