Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Injectors
Old Apr 18, 2007 | 08:46 PM
mp4805's Avatar
Injectors
anyone know the lbs./hr. that the stock camaro lt1 injectors are(1994). Will the ACCEL 26lbs./hr. work well and will the computer need reprogramed with the 26#'s ?
Old Apr 18, 2007 | 08:50 PM
z28_theantirice's Avatar
I think alot of people don't like the Accel injectors. Check out racetronix.com
Old Apr 18, 2007 | 08:53 PM
LiENUS's Avatar
Stockers are 24.91lbs according to the pcm constants table in my firebird.
Old Apr 18, 2007 | 08:57 PM
mp4805's Avatar
anyone have a favorite brand? are ACCEL's ok? i know the stock injectors seem to be poor quality
Old Apr 18, 2007 | 08:58 PM
96capricemgr's Avatar
Accel had a lot of issues for a long time, supposed to be corrected but who knows how much old stock is out there.
as said 24lbs is stock 26lbs would run but I would not leave it like that long term.
I also do not know the rated at pressure, different companies and applications use different pressures and this impacts flow rating.
Old Apr 18, 2007 | 10:55 PM
Why are the stock Rochester Product ball and seat injectors "poor quality"? From my experience, they are an excellent injector.
Old Apr 19, 2007 | 04:25 AM
94CamaroZ28's Avatar
More to the point, if you need injectors I can sell you my used stock LT1 injectors for 50 bucks shipped for the set. Off 94, no problems ever. No repriogramming involved.
Accel injectors suck. Search if you like.
There is little to no good reason I can think of to buy new injectors in a stock size, particularly Acell injectors.
Old Apr 19, 2007 | 07:01 AM
rskrause's Avatar
Moderator
What in the world is wrong with the stock injectors?
Rich
Old Apr 19, 2007 | 09:19 AM
Ram Air 383's Avatar
Accel injectors definitely have questionable quality. There is nothing wrong with stock injectors unless you're running very high fuel pressure (dry shot/fmu).
Old Apr 19, 2007 | 05:36 PM
transAMdriv3r's Avatar
just go to your local savage yard and pick some stock injectors up. there are plenty of cars that have them. (roadmaster, caprice, camaro, trans am, formula, fleetwood broughm). there are tons of caprices, im sure you will find at least one. just get the right years.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
