Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
MSD pro billet distributor question
Old May 9, 2007 | 06:56 PM
mrmint69's Avatar
Has any one had a problem with these? If so did you change the cam shaft on the car also? I am trying to see if it might have something to do with the dowel postition being in the wrong place. Mine is newer and i am concerned it might go out so i would like to see what is causing them to rub.
Old May 15, 2007 | 08:03 PM
The Engineer's Avatar
Possibly, if your cam dowel pin is too long it may be placing too much presssure on the opti keyed hub and shaft. If the pin was in the wrong position, the egnine would not run. What cam are you running?
WD
Old May 15, 2007 | 10:32 PM
Did you swap your 94 to the dowel pin driven vented model?
Old May 16, 2007 | 01:27 AM
mrmint69's Avatar
I was told the cam was swapped but it is hard to say. I know it is nothing radical if it was done so i assume it was just to sell the car for more money. My new opti is vented where the old one wasn't. It all looked to be fine during install but i guess it would only take a tiny bit to ruin it. It took me forever to line it up but when it went on it was with zero effort so maybe it will be fine.
RUENUF
May 25, 2016 08:10 PM
mr28
Apr 20, 2016 05:44 PM
RUENUF
Mar 13, 2016 03:39 PM
mr28
Nov 23, 2014 11:11 AM
