Closed loop permissives
I've never found a real answer for this with a set finite list as the code in the PCM would be.
I do however know of several variables which must be met.
Temperature of things like coolant which are in the constants tables
Also there is a timer from vehicle start, so if your car is already warmed up, it will stay in open loop mode for a number of seconds even though the temperature criteria are met.
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
tdigger9899
Sep 7, 2015 10:56 AM
