Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
No power?
Old May 11, 2007 | 03:15 PM
niteninja's Avatar
No power?
I searched, but didn't really find an answer so here goes...
I recently rebuilt my LT1 and after 3 years of sitting, I decided to replace the fuel pump. I siphoned out the old gas (maybe 2 gals) and dropped the tank, installed the 255lph, hooked it back up. Replaced fuel with 5 gals of 93 octane, and turned the key...no noise, no fuel pressure.
That's where my questions begin.
1) I checked the voltage at the back and only 4 volts were getting there. I replaced the relay, and PCM fuse. (12 volts at the relay and fuse)
2) I replaced the filter
3) I could not find the lost ground, or what ever is losing power, I ran two wires to the back. plugged them into the harness with 12 volts...no noise, and the pump isn't running.
4) I decided then to check my old pump, my spare LS1 pump, and my walbro pump...nothing...I had them in a jar of gas just to make sure I didn't run them dry.
If I run 12 volts to a pump...shouldn't it turn on? or am I missing something?
Please help
Derek
Old May 11, 2007 | 03:55 PM
You should be able to run the pump by supplying +12V to the gray "prime" connector by the PCM.
Sounds like you may have a wiring problem insie the tank, although its hard to understand why the stock pump wouldn't be working with a separate power supply.
Old May 11, 2007 | 04:00 PM
niteninja's Avatar
I was thinking that, but when I tried my old pump (didn't try before because one of my upgrades was fuel pump) nothing. I was originally swapping an ls1 into the car, but I was able to sell the LS1. I kept the fuel pump I receieved with the LS1, and nothing.
So that's 3 pumps that when supplied 12V+ to the pump...nothing.
I tried the "red" prime connector by the PCM but nothing, and it just heated up the plastic around the connector..didn't melt it, just warmed it up.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
