You don't need an aftermarket fuel pressure regulator to handle the Walbro pump. The stock regulator will do just fine in keeping the correct pressure.
I agree with the post above, your stock regulator will maintain the stock fuel pressure of 41 - 47 psi (measured with the vacuum line removed from the regulator to simulate WOT).
