Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pump question (general)
Old Feb 20, 2007 | 10:49 AM
reamo04's Avatar
do f-bodies have an access trap-door for the fuel pumps, or do i have to drop the tank to change it out?
Old Feb 20, 2007 | 11:00 AM
qboneus's Avatar
drop the tank or cut out a trap-door... search trap door method here it should net you the info you need.
Tal
Old Feb 20, 2007 | 11:22 AM
reamo04's Avatar
i cant find any how-tos on the trapdoor method, anyone want to help out?
Old Feb 20, 2007 | 11:30 AM
2000GTP's Avatar
http://www.worldisround.com/articles/12533/index.html
Old Feb 20, 2007 | 12:59 PM
myslowcamaro's Avatar
recently i have been spouting off if you have the time and/or money, to drop the tank and while it is out cut the trap door
1) less headache worrying about cutting lines if you cut too deep.
2)as 2000gtp pointed out before, aftermarket fuel pump manufacturers recommend flushing the tank prior to new pump install to limit the possibility of any problems from junk in the tank. so now you'd have a clean tank, new pump installed and a access door should you have any need to upgrade or replace the pump again.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
