Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Pressure Problems
Old Apr 10, 2007 | 08:23 AM
Grims's Avatar
Okay, after 3 new pumps, fuel pressure in the car still drops to 0 immediately after turning off the ignition. It idles at 36psi, and 47 WOT. The FPR, and fuel filter are relatively new...maybe a year old.
Ruling the fuel pump, and check valve out, what else would cause my fuel pressure to drop to 0 as soon as the ignition is turned off?
btw, the new pump is a walbro 255 in the bucket.
Old Apr 10, 2007 | 02:53 PM
Fuel pressure regulator damaged, leaking injectors, leaking lines.
Old Apr 10, 2007 | 03:08 PM
Grims's Avatar
Would leaky injectors cause the pressure to drop immediately to 0? None of the lines are leaking, so best bet is the regulator?
Old Apr 10, 2007 | 05:18 PM
It doesn't take much loss of fuel to drop the pressure. You can check the injectors by pulling the rails up and priming the pump.
Old Apr 10, 2007 | 10:02 PM
roguedriver's Avatar
What type of pressure gauge are you getting your reading from?
Ken R.
Old Apr 10, 2007 | 10:17 PM
Grims's Avatar
Okay, we just ruled out the FPR by hooking it up to another TA. Checked out the injectors and they're not leaking. We also can't find any line leaks. I'm totally lost now.
Old Apr 11, 2007 | 12:28 PM
Grims's Avatar
Ken R.
An analog fluid needle type, not sure on the brand, the car is at a friends house and he's relaying this information to me.
Old Apr 11, 2007 | 12:37 PM
markinkc69z's Avatar
Keep in mind that a single drop of fuel lost in a hydraulic system could drop the pressure to 0 from 40.
Old Apr 11, 2007 | 03:25 PM
Grims's Avatar
So, what should I check for on that?
Old Apr 11, 2007 | 06:14 PM
Are you having hard starting problems?
Old Apr 11, 2007 | 06:16 PM
Grims's Avatar
Yes, about 6 second starts.
Old Apr 13, 2007 | 08:38 AM
Grims's Avatar
Still working on it, anyone have any other ideas?
Old Apr 13, 2007 | 08:55 PM
94SLUG's Avatar
I had same problem it was the regulator (Aeromotive was no good stock unit is fine up to 900hp).. Went back to the stock unit and had no problem. The cpu controls FP anyway... Good Luck....
Old Apr 14, 2007 | 05:23 AM
How does the cpu control fuel pressure? It has no way of even knowing the fuel pressure. It will adjust the injector pulse width to compensate for a lean condition caused by low fuel pressure, within limits, but the PCM does not control the pressure.
Interesting that you mentioned problems with the Aeromotive AFPR. Seems to be a frequent problem.
Old Apr 15, 2007 | 11:32 AM
Grims's Avatar
Found the problem, and it ended up being something pretty stupid. The kink free plastic hose that came with the pump was to large to completely seal on the out take nipple of the fuel pump. We replaced it with a rubber hose and it now hold pressure great.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
